Create webPage link from interface of ScadaAdmin
Forum Home Forums Uncategorized Issues Create webPage link from interface of ScadaAdmin
  • #5282
    SuperDev
    Hi Mikhail
    according to BaseUiTypes {View, Report, DataWnd} in ScadaData, if the path we enter in interface of scada Admin isn’t one of the above mentioned typeCodes, it will be WebPageView. Right?
    I want to load html file in scada like Events.aspx or external website like http://www.google.com.
    Now, the question is how i should define the (html or aspx) file or external website link in interface of SCADA Admin?
    I expect to have listed the link in Views
    #5284
    It detects http:// or https://
    In the Interface table just type http://google.com
    #5285
    SuperDev
    But When i want to load internal pages i get NoView error in some case.
    Specifically about Events.aspx.
    I write the followings in interface
    This way:
    http://localhost/Scada/plugins/Table/Events.aspx
    and this way:
    /Scada/plugins/Table/Events.aspx@WebPageView
    None of them work and give NoView error
    Would you please help
    • This reply was modified 7 years, 5 months ago by SuperDev.
    #5287
    Events.aspx doesn’t work because of internal check, however http://localhost/Scada works. There is something wrong with caching a link. You should restart application pool or website after changing links.
    #5288
    SuperDev
    So I want to write my own plugin according to existing PlgTable and events.aspx
    Would you please tell me which part and lines of code in existing Events.aspx or other files have internal check? And what i should do in my own plugin to cover that problem?
    Thanks a million
    #5290
    Here.
    The next time you should find such answer by yourself using VS debugger.
    It depends on logic of your plugin.
    #5292
    SuperDev
    Thanks àlot
