Viewing 15 posts - 3,781 through 3,795 (of 6,391 total)
  • in reply to: Download configuration remotelly #7071
    It means that the configuration is too big (more than 10 MB). When configuration is transferred, it is zipped to reduce size. So 10 MB is a size of an archive.
    There are 2 options how to fix:
    1. Check your interface files. May be you should optimize images.
    2. Increase maxReceivedMessageSize in C:\SCADA\ScadaAdmin\ScadaAdmin.exe.config
    • This reply was modified 6 years, 2 months ago by Mikhail.
    in reply to: read modbus register as ASCII #7068
    1. Read the registers from 30215 to 30218 as a double (8 bytes) in Communicator. They will be passed to a one input channel.
    2. Check the displayed value.
    Share new screenshots, please.
    in reply to: Chart Pro does not show charts #7067
    Hello Irene,
    It looks like the configuration file of Chart Pro is not included in the project. Please find PlgChartPro.xml in the distributive package of Chart Pro and copy it to YourProject\Instances\Default\ScadaWeb\config\ directory.
    Then upload the project to the server.
    in reply to: ChartPro – Excel Export Option #7066
    Chart Pro supports export channel values to Excel.
    in reply to: Download configuration remotelly #7057
    The additional error information is in C:\SCADA\ScadaAdmin\Log\ScadaAdmin.err
    Please provide the error details from the log.
    in reply to: Variable limits in extra scheme components #7054
    Min and Max are constants. That’s true. As a work around you could create an extra input channel of the Calculated type. And set a formula to calculate some kind of relational value.
    i would like the right picture, but the colors of the ring changing with time regarding a variable bandwidth.
    The right picture uses a background found somewhere in the internet. A display over a gauge is a dynamic text component.
    in reply to: Toggle color #7052
    The values in the table, also black, not red and green. This means that input channels are not configured properly. You should also set the Unit field to Off-On.
    in reply to: Try to integrate with IED using DNP3 Protocol #7050
    Please contact us by email for more info.
    in reply to: Toggle color #7049
    Create a table view to check color of values.
    in reply to: Error state on device #7043
    Sorry, I mean:
    Open Line 2 Parameters – Request Sequence, select the device 1 and then make a screenshot.
    in reply to: Cloud connection #7040
    It’s possible to deploy a virtual machine in the cloud (Google, Azure, AWS, etc.) and install Rapid SCADA on that machine.
    For our servers we use different providers. You should select your favorite.
    in reply to: Toggle color #7039
    Did you upload the project after change?
    in reply to: Call command from formula #7035
    You need Automatic Control Module for this purpose.
    in reply to: Toggle color #7034
    Change channel type to Discrete
    in reply to: Error state on device #7033
    Timeout can be only be set to ‘System.Threading.Timeout.Infinite’ or a value > 0.
    Please make a screenshot of the device properties in Communicator.
