1. Read the registers from 30215 to 30218 as a double (8 bytes) in Communicator. They will be passed to a one input channel.
2. Check the displayed value.
Hi, Mikhail double (8bytes) worked. as shown in below link read as double
if I would like to convert the 20 bytes ascii string (they are all numbers) to number, so the values can be stored in the database and be shown on the chart.
do you have suggestion for that, any tested formular?
You should develop a formula by yourself. The idea is the following:
1. Create an input channel of the calculated type.
2. Add a formula in the Formulas table
double MyFunc()
// your code here
3. Use this formula for the created input channel.
