Viewing 15 posts - 3,256 through 3,270 (of 6,392 total)
  • in reply to: Scan Time #8544
    What you can do to decrease CPU load:
    1. Use RAM disk for C:\SCADA\ScadaComm\Log directory.
    2. Add this log directory to antivirus exception.
    3. Increase delays after request in request sequence or after line cycle.
    in reply to: Sendig email: Error: incorrect command data #8543
    Please make a screenshot of the command text when you send email.
    in reply to: Computer code for plugin #8542
    It is shown in the web form. It’s depends on the plugin, see the manual for details.
    What plugin do you mean?
    in reply to: Current Data Export #8536
    OK
    in reply to: Scan Time #8535
    Could you make a screenshot of the CPU usage by processes (Task Manager)?
    in reply to: Add new channel inputs and commands #8534
    The Channel column is empty in “Device 1” tab. It means that input channels are not bound to the device.
    Make sure that the project is uploaded to the server, and Communicator is connected to the Server application.
    in reply to: Current Data Export #8522
    The module writes log files that are located in C:\SCADA\ScadaServer\Log
    Please copy meaningful parts of log files in this topic.
    in reply to: Mono high cpu usage #8521
    Great!
    in reply to: About Elastic Report Month Period #8520
    You should check a report example on Live Demo. But a year step is not supported, max. step is 1 month.
    in reply to: Scan Time #8519
    According to the log, your polling rate is about 1 second. It depends on network latency and controller speed.
    So you need pulse length at least 2 seconds to detect it stable.
    in reply to: Scan Time #8513
    Can you explain the Timeout; Delay; Time ; Period; entries please
    Please read this. If something is not clear in the article, ask.
    Could you post a part of communication line log here to analyze? It’s in Line Stats
    in reply to: Scan Time #8510
    where do I set up the polling rate ?
    It’s in Communicator – Communication line – Line Parameters – Request Sequence
    in reply to: Open in Web Browser #8507
    When I try to add rights to the role, in the role tab – there is nothing in the interface Object.
    You should press the Refresh button above the table to fill drop down lists of the cells.
    Now I have an issue where no users can access the pages, even admin and guest
    Please start a new topic to discuss this issue. Provide screenshots of the Roles and Users tables.
    in reply to: Mono high cpu usage #8504
    Interesting. Reloading the entire web server just to start new log…
    Does the new approach stop reloading?
    in reply to: Scan Time #8503
    You need to specify a pulse length and polling rate. And make sure that polling rate is fast enough to detect a pulse.
