Elastic Report: Reports on different Views other then Main View/Reports
Forum Home › Forums › Understanding the Software › Elastic Report: Reports on different Views other then Main View/Reports
  • #7821
    jacklondon
    Hi Mikhail,
    is it possible to publish elastic reports (@ElasticRep) on a different view other then Main View/Reports location, i.e. Main View/Demo/Reports?
    Regards
    #7822
    jacklondon
    OK, i found a workaround: Take the link of the report and add it to the interface, where you would like to have the report!
    http://xxx.xxx.xxx.xxx/scada/plugins/ElasticReport/ElasticRep.aspx?reportID=XY
    But, is it also possible to have the definition of the (report) view directly embedded at the interface definition instead of xxx.xml@ElasticRep?
    #7824
    Currently, using links is the only way to display reports among views.
