Input channel works for incoming data. Output channel works for commands. Checkbox for output channel means writing an event when command is sent.September 23, 2022 at 9:41 am in reply to: Continue sending command to Modbus device using Auto Control Module #10894
There is a repeat commands checkbox of a data trigger. If you provide a screenshot of your trigger, I can give more exact info.-
This reply was modified 4 years ago by
September 22, 2022 at 10:27 am in reply to: How to Install Automatic Control Module in Raspberry PI #10886
MikhailModerator🙂
MikhailModeratorCan you see the screenshot of the archive settings?
No, I can’t.
MikhailModeratorAt least a screenshot should contain an event.
The SQL request is executed every time when new data comes from Communicator to Server service.
MikhailModeratorTry the formula that works for v5 and v6:
public int MyStat() { if (1 <= Cnl && Cnl <= 2) // your limits return 100; // your status else if (3 <= Cnl && Cnl <= 4) return 200; else return 300; }In the channel formula:
Cnl; MyStat()
MikhailModeratorIf you have questions for now, be free to ask.
MikhailModeratorThe above screenshots do not contain a panel of Notification panel plugin. It is shown automatically when a new event matches the plugin settings.
You can see this panel when click the Bell button.
MikhailModeratorCould you provide a screenshot of the archive settings?
MikhailModeratorSystem.Private.Uri is a part of .NET. May be you should install Chinese language pack for .NET.
You can try downloading the dll from https://www.nuget.org/packages/System.Private.Uri/ , unzip it and copy the requested file into SCADA\ScadaServer\Mod\ModArcInfluxDb.Logic\ directory.September 21, 2022 at 7:26 am in reply to: How to Install Automatic Control Module in Raspberry PI #10853
It looks like the module is not in use.
Check that /opt/scada/ScadaServer/Config/ScadaServerConfig.xml contains
<Module code="ModAutoControl" />
mode can be fixed or rolling
period is a number of days in fixed mode or minutes in rolling mode
config is a chart configuration file.
Could you make a screenshot of a notification panel of the plugin that contains an event?September 21, 2022 at 7:20 am in reply to: How to manage MQTT JSON data from Rapid Scada version 6 beta #10850
MikhailModeratorHow can I update to the new release keeping all of my settings ?
– Make a backup of your Rapid SCADA project
– Upgrade Rapid SCADA
– Upload the existing project
– Check for errors -
