Forum Home › Forums › Understanding the Software › Application Error Plug-in Elastic Report
- This topic has 4 replies, 2 voices, and was last updated 4 years, 5 months ago by
ilhampngst_.
April 9, 2022 at 2:57 am #10165
ilhampngst_
ParticipantHello,
I just tried the elastic report feature, after all the steps for the installation, but there was an error like the picture I attached and how to solve it?
https://drive.google.com/file/d/10EMz5mGTL1jO-989DD6akc5JAaZVOUzu/view?usp=sharingThanks
April 10, 2022 at 9:08 am #10166
Please check the error details in the log C:\SCADA\ScadaWeb\log\ScadaWeb.log
Looks like the report configuration file is not uploaded.April 10, 2022 at 9:34 am #10168ilhampngst_
ParticipantHello Mikhail good too see you.
After I read the error log, it turns out that I am still confused to find out where the error is, and how do I upload the configuration report2022-04-10 16:27:27 <PC-DC-1><DefaultAppPool><ACT> Check “Elastic Report” registration:
Registration key is valid. Expiration date is 11/04/2022
Computer code: =C7C786A1F0AF9FFF-E47864D34DF4CF7C-A138622D90CE8062-304A791309DCAA8B-CB3305D70FBE05DF-0BBB714CE6180BDE-E6989782AF664F5F-2ADB6D3F8B9872BE-3659648136445418-2E56689EC0F3224E-A1416C1D8E537123-8A935F26B22499BC-90CC02D0DC5FEC3F-5ED00B324A166A7C-B3CA60682351D9E5-9FFC1200FBEFB3A1=
2022-04-10 16:27:27 <PC-DC-1><DefaultAppPool><ACT> Request SCADA-Server state
2022-04-10 16:27:27 <PC-DC-1><DefaultAppPool><ACT> Disconnect from SCADA-Server
2022-04-10 16:27:27 <PC-DC-1><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2022-04-10 16:27:27 <PC-DC-1><DefaultAppPool><EXC> Error receiving user interface object from SCADA-Server: Error loading elastic report configuration: Root element is missing.
2022-04-10 16:27:27 <PC-DC-1><DefaultAppPool><EXC> Application error:
Scada.ScadaException: Unable to receive elastic report configuration.
at Scada.Web.Plugins.ElasticReport.Config.ElasticRepConfig.GetConfig(Int32 reportID, String path, Cache cache, ServerComm serverComm)
at Scada.Web.Plugins.ElasticReport.WFrmElasticRep.Page_Load(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Page: http://localhost/Scada/plugins/ElasticReport/ElasticRep.aspx?reportID=1004
User: adminApril 11, 2022 at 10:00 am #10172
When a report is just created, its file is located inside the project like shown here https://rapidscada.net/doc/content/latest/en/modules/plg-elastic-report-files/report_itf_file_en.pngAfter you send the project to the runtime by clicking the upload button, the report configuration file should be located in C:\SCADA\Interface
Do you have such file?
April 18, 2022 at 7:51 am #10194ilhampngst_
ParticipantThanks Mikhail its work properly 🙂
