Viewing 15 posts - 211 through 225 (of 6,387 total)
  • in reply to: Evento de perda de comunicação – Rapid SCADA 6.2.2 #17705
    I disabled the device in the line configuration to simulate a communication error or a device fault.
    This test simulates the service shutdown, but not a device failure.
    To simulate a device fault, switch off the device.
    in reply to: Dashboard error #17701
    Note that the registration key in ScadaWeb.log differs than the entered key. Make sure that after uploading the project and restarting the web application, the key file PlgDashboard_Reg.xml is updated in the C:\Program Files\SCADA\ScadaWeb\config directory
    in reply to: GetChannelName #17698
    In the script, executed by the Server service, it is possible to get the name (and other properties) of the current formula’s channel only.
    Getting names of any channel by channel number is available in the code of a software module that can be developed by you.
    • This reply was modified 7 months, 1 week ago by Mikhail.
    in reply to: Evento de perda de comunicação – Rapid SCADA 6.2.2 #17694
    How do you disable the device?
    The solution depends on whether the device is in a physical error state or whether the device is disabled in the software settings.
    in reply to: Dashboard error #17692
    It is better.
    We can see that the dashboard view type is recognized (icon in tree), but the page is not found. Press F12 to check the console what URL is not found.
    in reply to: Evento de perda de comunicação – Rapid SCADA 6.2.2 #17689
    All values are gray. You should check that Communicator is running and the device data is being updated in Communicator.
    Gray color means that data is not coming from Communicator to Server.
    • This reply was modified 7 months, 2 weeks ago by Mikhail.
    in reply to: New release Rapid SCADA 6.4.x #17687
    Rapid SCADA 6.4.5 has been released.
    – New mimic diagrams and components have been updated.
    – Historical data reading has been implemented in the OPC UA driver.
    – Bug fixes.
    in reply to: Dashboard error #17675
    Thanks.
    The settings look correct.
    According to ScadaWeb.log, you use
    ScadaWeb 6.2.1.0 (April 01, 2025)
    PlgDashboard 6.1.1.0 (August 26, 2025)
    I suppose, they are incompatible. I suggest to upgrade the web application to ScadaWeb 6.2.3.0 (December 20, 2025)
    Version history is here.
    in reply to: Issue in Sending command(Modbus RTU) #17674
    In your case, you don’t need to create a separate command node in the Modbus template. An element could be read and written if it is not readonly.
    in reply to: Evento de perda de comunicação – Rapid SCADA 6.2.2 #17673
    Using formula CnlStat > 0 ? 0 : 1 is also possible. But the method described above is simpler.
    in reply to: Evento de perda de comunicação – Rapid SCADA 6.2.2 #17671
    Just create a new channel of the Calculated type, and set the Tag Code field to Status
    The device field of the channel should refer to the certain device.
    Then upload the project changes and check value of the newly created channel.
    Provide a screenshot of your settings if it doesn’t work.
    in reply to: Dashboard error #17660
    Access to the files is denied.
    in reply to: Dashboard error #17656
    ScadaWeb.log is OK.
    To add a screenshot, publish it on Google Drive, and post link here.
    in reply to: Dashboard error #17653
    Please send the details from ScadaWeb.log and screenshots of the settings related to the issue.
    in reply to: I can’t open or Edit Mimic Files. #17651
    The main idea from my manager is to use Windows only to create local projects and use Linux (our server) strictly as the runtime to collect data from those projects and display them in WebStation.
    In this case, the correct way is editing the project on Windows workstation and then upload it to the Linux server for execution. Use GIT for managing project versions.
    In the next version of Extra Mimic Components, a key will not be required for editing mimics.
