Calculated Channel computing current minimum value of multiple channels
Forum Home › Forums › Understanding the Software › Formulas › Calculated Channel computing current minimum value of multiple channels
  • #16970
    rapidscadaaks
    Hi
    Please assist for making a formula to calculate minimum value of current date of several channels.
    I excel, one would have used min(aa:xx)
    Thanks in advance
    #16971
    rapidscadaaks
    Hi
    Thanks in advance
    #16976
    rapidscadaaks
    Hi
    I used formula below in a calculated channel and it did not work:
    Min(Val(1601),Val(1602),Val(1603))
    Server returned following error:
    2025-09-08 09:16:30 [SCADA][SCADA$][ERR] Error compiling the source code of the scripts and formulas:
    (929,53): error CS1501: No overload for method ‘Min’ takes 3 arguments
    Check the source code in Z:\SCADA\ScadaServer\Log\CalcEngine.cs
    2025-09-08 09:16:30 [SCADA][SCADA$][ERR] Normal execution is impossible
    Please help
    Thanks in advance
    #16977
    rapidscadaaks
    Found a solution by using following script
    public double GetMinValue(params int[] channelNumbers)
    if (channelNumbers == null || channelNumbers.Length == 0)
    return double.NaN;
    double minVal = double.MaxValue;
    foreach (int cnlNum in channelNumbers)
    minVal = Math.Min(minVal, Val(cnlNum));
    return minVal;
    #16985
    Creating formulas is a development service and is outside the scope of support. If you have a specific question about the syntax or features of formulas, please ask.
    #16986
    Note that is is not efficient to pass an array as a function argument. Because a new array is created each iteration.
    It’s better to make a function like
    public double GetMinValue(int cnl1, int cnl2, int cnl3)
    #16989
    rapidscadaaks
    Noted Mikhail.
