“IF” Formula in channels
Forum Home Forums Understanding the Software Formulas “IF” Formula in channels
  • #16754
    rapidscadaaks
    Hi
    Is it possible to use “if” formula in channels? If so, please assist in syntax.
    #16758
    For example
    Cnl > 100 ? 1 : 0
    #16765
    rapidscadaaks
    Thanks for the tip. Please advise how to use data of 2 channels for returning 1 or 0
    Many thanks in advance
    #16773
    Could you provide an example as text?
    #16956
    rapidscadaaks
    Hi
    I wanted guidance for the following example :
    Channel AA is having value of 0 or 1
    Channel BB is having a value between 0 and 4
    I would like Channel CC to return 1 if Channel AA is 1 and Channel BB is <=2 or >=3.5 else 0
    Thanks in advance
    #16957
    rapidscadaaks
    I created a Calculated Channel and observed that (||) works but (&&) does not work. Please guide
    #16959
    Both || and && work for boolean expressions.
    For more info, check the error in ScadaServer.log.
    #16964
    rapidscadaaks
    Please guide for the following example:
    Channel AA is having value of 0 or 1 coming from a script which mentions “double”
    Thanks in advance
    #16984
    Channel CC formula could be
    Cnl(101) == 1 && (Cnl(102) <= 2 || Cnl(102) >= 3.5) ? 1 : 0
    101 is AA.
    102 is BB.
    Not tested.
    #16988
    rapidscadaaks
    Thanks Mikhail for your revert which is extremely helpful.
    Just one question : what is the difference between using Cnl(101) and Val(101) ?
    #16998
    Cnl(101) is a mistake, use Val(101).
