Roles for map view
Forum Home › Forums › Understanding the Software › Roles for map view
  • #16990
    oley
    I’ve created some users and roles.
    My map view shows all the objects and is not assigned to any object itself.
    I want that the user sees his objects and also the map view.
    Should I create a fake MapObject and assign it to the map view?
    #16996
    Channels are related to objects. You can create an object and use it for all channels.
    #17001
    oley
    I have several objects, let’s say PV1, PV2, PV3, PV4, which are shown on the map. The administrator can see all objects, of course.
    I assign objects PV1 and PV2 to user U1, and PV3 and PV4 to user U2.
    After logging in, users can only see views of their own objects, but they cannot see the map, because it is not assigned to any object, but is a collective view of all objects.
    Ideally, user U1 would see the map with their objects PV1 and PV2, etc.
    #17003
    <Param name=”accessToken” value=”pk.eyJ1IjoibWFwYm94IiwiYSI6ImNpejY4NXVycTA2emYycXBndHRqcmZ3N3gifQ.rJcFIG214AriISLbB6B5aw” />
    this is possible. Like it’s a demo token, but you need a custom one. If so, then for each client it is necessary to register and receive a token, perhaps then it will be tightened.
    I didn’t check it. This is in the map configuration
    #17008
    Currently, a map view does not check access rights for each particular object.
    Could you describe how your system is used? I’d like to imagine this case.
    #17020
    oley
    Finally, there will be about 20-30 objects in the system.
    The administrator can see/control all of them and select them from the map.
    These objects are assigned to users/owners who should only see their own objects — this works after defining roles.
    I would like the user/owner, after logging in, to:
    – see the map
    – see only their own objects on it
    Every user owns 1-4 objects.
    #17027
    It is impossible to implement such a possibility this year, but it would be good to implement it. If you remind me in January, there is a chance that it will be done.
    #17040
    oley
    thank you, I will come in January with this topic.
