Make sure that you downloaded the latest version of components (plg_sch_extra_comp_6.0.1.0_en.zip) which contains ScadaSchemeEditor\Web\bin\PlgSchExtraComp.dll
MikhailModeratorThe Administrator application should be installed on Windows. It interacts with Rapid SCADA instance, which is installed on Linux, remotely. You should add a new deployment profile in Administrator for remote connection.
MikhailModeratorJavaScript API allows to request events. However, this approach requires development of a component that implements this feature. We could help you to develop such component, or can add this feature to the wish list.
This reply was modified 3 years, 1 month ago by
Please provide links to the screenshots of the settings.
What is the DB Export module version?
Note: The Automatically accept certificates checkbox should be unset in production environment. I’m not sure, may be the driver stores a certificate into the storage after it is accepted. Otherwise, it should be copied manually.
September 5, 2023 at 9:12 am in reply to: Unable to cast COM object of type ‘System.__ComObject’ #13296
This topic is useful to avoid such mistake. Let it be.
September 5, 2023 at 9:11 am in reply to: How to use a c# script to process input XML/MQTT message #13295
1. Add your scripts into the Scripts (v6) or Formulas (v5) table.
2. Write a DLL in C# using the examples from GitHub.
3. The MQTT driver support JavaScript.Please specify your question.
MikhailModeratorIn Chinese please write in this subforum. Or use English.
MikhailModeratorI did the following test:
1. Use the default settings of the OPC UA Server data source. The Automatically accept certificates checkbox in set.
2. Install and run Prosys OPC UA Browser.
3. In Prosys OPC UA Browser
– Security settings: Sign, Basic256Sha256
– User auth: username and password (opc / scada)
4. When connect, the client asks to accept the certicicate.
5. Connected successfully.Note: the same machine for client and server.
Could you repeat this test?-
MikhailModeratorIf you need to check all existing events associated with a channel, it’s possible, but may slow down the performance.
You can load an event by ID and check the Ack field.
Do you use Rapid SCADA 5 or 6?
MikhailModeratorI can check this issue the next week.
Copy the plugin configuration files from the installation ZIP to the project.
And as written above activate Chart Pro in the project using the Administrator app.
There is no recent changes in custom pages.
“Blazor is a feature of ASP.NET for building interactive web UIs using C# instead of JavaScript” So it’s a client feature.
We don’t plan to use it because we afraid it could be “Silverlight II”.
MikhailModeratorDo you get an error in the client if you try to connect using Basic256Sha256 if the OPC server uses the default settings? What error?
