Show object hierarchy in tree view (Channels)
Forum Home › Forums › Development and Integration › Show object hierarchy in tree view (Channels)
  • #12558
    Davy
    We plan to implement a new view in the “Channels” node. In order to group channels by objects.
    For this we propose to add a new node under “Channels” called “Channels by objects”.
    All objects will appear hierarchically under this new node.
    To move multiple channels into an existing object, we’ll add a new drop-down button to the channel list “Move to object…”
    Any advice or suggestion about this feature?
    #12563
    The new features sounds useful. Could you provide links to the screenshots in this topic?
    #12564
    Davy
    Drop-down button in the channel list :
    https://zupimages.net/up/23/19/un5z.png
    Node under “Channels” called “Channels by objects” :
    https://zupimages.net/up/23/19/9s68.png
    • This reply was modified 3 years, 6 months ago by Davy.
    • This reply was modified 3 years, 6 months ago by Mikhail.
    #12578
    Thank you for the screenshots.
    In my opinion, an object tree to filter channels by object is very useful.
    Could you explain how the tool to move channel works?
    P.S. Please use https://imgbb.com/ or Google Drive to publish screenshots. zupimages.net works only via VPN for me.
    #12579
    Are the described developments implemented as extensions that can be easily enabled in Administrator?
