詹森
Viewing 15 posts - 16 through 30 (of 55 total)
  • in reply to: Send Commond #16592
    詹森
    I have found that there are significant limitations in using the automatic control module. Can it be further improved in the future? For example, “Multi-Channel Data Trigger” can select another channel for copying the Value, which is very commonly used
    Also, what does “my own module” refer to? How is it achieved?
    Could you please tell me? Thank you
    in reply to: The archived file is lost. #16558
    詹森
    Understand,Thank you for your answer
    詹森
    Thank you. Will give them a try.
    in reply to: The archived file is lost. #16542
    詹森
    I’m using an ubuntu system device. I’d like to ask why “min20250629_0001.dat” was created at 08:59? What if it is not created at 0 o ‘clock?
    in reply to: The archived file is lost. #16533
    詹森
    The files being viewed range from min20250629_0001.dat to min20250629_0013.dat. Under normal circumstances, there are min20250629_0001.dat to min20250629_0024.dat
    詹森
    Hello, could you provide more detailed instructions on how to use this feature? Here’s my understanding—please confirm if it’s correct:
    I set the Tag Code of the channel to Status.
    How can I start or stop communication lines via Server commands?
    Specifically, how do I use CommCmdCode.AddressedToComm() to control the start/stop of a specific line?
    Thank you!
    in reply to: information of the Archive #16498
    詹森
    OK,Thank you
    in reply to: information of the Archive #16493
    詹森
    The problem has been solved. Just as you said, replacing the file has nothing to do with the directory
    in reply to: information of the Archive #16490
    詹森
    Thank you for your help,thankful
    in reply to: information of the Archive #16488
    詹森
    Look at the latest pictures I sent. All the files have been recognized. I have confirmed that there are files and they are all recognized, but they can’t be opened. This indicates that there are files and data. It seems that the tool software can’t open them. Could you please help confirm this? Thank you
    in reply to: covert channel #16394
    詹森
    Hide the “Active” of Channels similar to those in the Configuration Database. After unchecking “Active”, the channels will not be displayed directly
    in reply to: covert channel #16393
    詹森
    My supplementary description is that for the Table file that needs to be added in the Web, it will be displayed when the channel value is 1. When the channel value is 0, the channel will not be displayed in the table. How can we directly hide this channel?
    in reply to: information of the Archive #16376
    詹森
    in reply to: information of the Archive #16375
    詹森
    I tried to run the HelloWorld project for about ten minutes, generating records every minute. When I opened it, I still didn’t see any data. The pictures were the same as before. Could you please help me take a look? Thank you!
    in reply to: information of the Archive #16363
    詹森
    picture1 : picture1
    I have downloaded and opened the file. I configured “Archive” in the Channel, but when I opened the downloaded file with the software you provided, I didn’t find any data. I confirmed that the file size is 4M. When I changed the file to another device, it also displayed as shown in the picture. Is this normal? Thank you!
