TDE
Viewing 10 posts - 31 through 40 (of 40 total)
  • TDE
    Yes. it works
    TDE
    Hi Henni,
    Can u please show me how you define it in the channels table?
    TDE
    When I reinstall Rapids cada and check the status of server and the comm I find that they are both normal but after the upload of the project the comm’s status change to error.
    in reply to: Webstation URL #12332
    TDE
    You mean this URL: http://localhost:10008/Login ?
    TDE
    Hi Mikhail,
    I check it before. They have the same secret key.
    in reply to: How to setup Event #12322
    TDE
    How can use auto control module (please mention the steps) to create an event of changing the status of Boolean tags and after 5 seconds it returns to the old status.
    Cordially
    in reply to: Server is unavailable #12321
    TDE
    in reply to: Restart Scada #12294
    TDE
    I restarted the Scada-server service from status instance to get the computer code for registration but it’s only blank. (please see the link: https://drive.google.com/file/d/1S8P9pfo6sNd4IHbBi_-PC5VfUMS1GNdV/view?usp=share_link)
    How can I get the code please?
    in reply to: GetBit Error #12289
    TDE
    What GetBit((-1), 0) refer to?
    in reply to: Installation problem RapidScada 5 #12250
    TDE
    Trying to install latest RapidScada 5.8.4 to Windows 10 Home 64bit with latest updates.
    Installation gives notes and error:
    Install Server application
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaServer.zip
    Install service ScadaServerService
    Installation of Server application has completed successfully
    Install Communicator application
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaComm.zip
    Install service ScadaCommService
    Process completed with an error
    Installation of Communicator application has completed with a error:
    Service ScadaCommService hasn't been installed
    Check the configuration of Internet Information Services (IIS)
    Go to
    Control Panel > Programs > Turn Windows features on or off
    and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
    whereas the components for .NET Framework 3.5 are switched off
    Check Windows Communication Foundation (WCF)
    Register ASP.NET
    Install Webstation application
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaWeb.zip
    Selected application pool: DefaultAppPool
    Register web application Scada
    Create shortcut Webstation
    Installation of Webstation application has completed successfully
    Install Agent application
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaAgent.zip
    Install service ScadaAgentService
    Installation of Agent application has completed with a error:
    Service ScadaAgentService hasn't been installed
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaAdmin.zip
    Create shortcut Administrator
    Installation of Administrator application has completed successfully
    Install Scheme Editor application
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaSchemeEditor.zip
    Installation of Scheme Editor application has completed successfully
    Install Table Editor application
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaTableEditor.zip
    Installation of Table Editor application has completed successfully
    Installation has completed with errors
    Please restart the computer
    • This reply was modified 3 years, 8 months ago by Mikhail.
