Forum Home › Forums › Runtime Bugs › Communicator Bugs › Unable to start communication lines because the configuration database is not re
- This topic has 7 replies, 2 voices, and was last updated 3 years, 7 months ago by
March 29, 2023 at 7:29 pm #12323
TDE
I tried to run the webstation but the status of comm is not normal (error)
this messages appear in the comm logServer and client secret keys do not match.
2023-03-29 12:25:55 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Unable to start communication lines because the configuration database is not received
2023-03-29 12:26:03 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ACT] Data source ScadaServer: Receive the configuration database
2023-03-29 12:26:05 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Data source ScadaServer: Error checking server connection:
2023-03-29 12:26:05 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Unable to start communication lines because the configuration database is not received
2023-03-29 12:26:13 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ACT] Data source ScadaServer: Receive the configuration database
2023-03-29 12:26:15 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Data source ScadaServer: Error checking server connection:
2023-03-29 12:26:15 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Unable to start communication lines because the configuration database is not received
2023-03-29 12:26:23 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ACT] Data source ScadaServer: Receive the configuration database
2023-03-29 12:26:25 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Data source ScadaServer: Error checking server connection:
2023-03-29 12:26:25 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Unable to start communication lines because the configuration database is not received
2023-03-29 12:26:33 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ACT] Data source ScadaServer: Receive the configuration database
2023-03-29 12:26:35 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Data source ScadaServer: Error checking server connection:
2023-03-29 12:26:35 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Unable to start communication lines because the configuration database is not received
2023-03-29 12:26:43 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ACT] Data source ScadaServer: Receive the configuration database
2023-03-29 12:26:45 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Data source ScadaServer: Error checking server connection:
2023-03-29 12:26:45 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Unable to start communication lines because the configuration database is not received
2023-03-29 12:26:53 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ACT] Data source ScadaServer: Receive the configuration database
2023-03-29 12:26:56 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Data source ScadaServer: Error checking server connection:
2023-03-29 12:26:56 [DESKTOP-OKTC1LV][DESKTOP-OKTC1LV$][ERR] Unable to start communication lines because the configuration database is not receivedCan you inform me where is the prob
March 30, 2023 at 8:31 am #12327
Check that the Server service and clients use the same secret key:
Server – General Options – Listener Options
Communicator – General Options – Connection Options
Webstation – Application Options – Connection Options-
This reply was modified 3 years, 8 months ago by
March 30, 2023 at 2:16 pm #12331TDE
ParticipantHi Mikhail,
I check it before. They have the same secret key.
March 30, 2023 at 2:39 pm #12333TDE
When I reinstall Rapids cada and check the status of server and the comm I find that they are both normal but after the upload of the project the comm’s status change to error.
March 31, 2023 at 9:11 am #12341
By default, the HelloWorld project is installed.
If you open and upload HelloWorld again, does it work correctly?March 31, 2023 at 8:48 pm #12343TDE
Yes. it worksMarch 31, 2023 at 9:00 pm #12346TDE
ParticipantBut the problem is still present
April 3, 2023 at 8:20 am #12352
MikhailModeratorYou should check the project configuration.
