There is GetBit formula inside the Dictionary under Administrator. I would like to get the bit 0 or bit 1 value from register address 30001. It reported with server stop when I use the formula GetBit(Val(106),0) or GetBit(Val(106),1). Or I should use the formula GetBit(106,0) and GetBit(106,1). Not sure if this can get the bit status of register address 30001 (channel number 106). Not sure if this is the bug or my typo error here.
Val(106) – Channel value number 106
106 is just a channel number, you will always receive a bit from the number 106, and converted to double by the system beforehand
If you need only one bit from the incoming signal, and you are not interested in the number itself and other bits, then you can simply use the GetBit(Cnl, 0) formula in the input channel without resorting to calculation channels
