April 20, 2023 at 2:16 pm in reply to: Time difference between mysql DB and rapid scada server #12475
TDE
Participant1- Time in rapid scada.log: https://sm.ms/image/ZWGUvBPe5Fnwa2M
2- The exported time_stamp: https://sm.ms/image/ZWGUvBPe5Fnwa2M
3- Query configuration:https://sm.ms/image/ZWGUvBPe5Fnwa2MTDE
ParticipantI want to mention also that the delay is set for 0 sec but the problem is the same.
TDE
ParticipantHi Mikhail,
We tried to send two commands in the same time (with one button) but it seems there is a delay between the status changes of the two tags (When the condition of the channel tag is correct the command to activate the 2nd tag will be sent after almost 1s).
Could you please help us to fix that delay.
Thanks in advance
TDE
I checked the communicator log and that what shows
https://drive.google.com/file/d/1nzeDL6y2V9AgFoiE9yuJManxuA64KAIu/view?usp=share_linkPlease help me
TDE
ParticipantSorry for the mistake.
TDE
Can you tell me the what is the cause please
Regards
https://drive.google.com/file/d/1d2YVi99k_jCBPPK5BO4Dl9jLqfVRZXTG/view?usp=share_link
TDE
Regards
This reply was modified 3 years, 7 months ago by
TDE.
TDE
ParticipantThanx a lot it works with me.
TDE
Can you give me a brief illustration?TDE
ParticipantCan u plz tell me how to make a dynamic text appears and a LED appear on the same time ones we click on a button?
TDE
ParticipantCan you please tell me how to use it?
TDE
Can you tell me how to do exactly the third step (3. Setup links on the main scheme to open popups by view ID.)
Regards
TDE
ParticipantCan I use one bottom to call an excel file. If yes please inform how?
March 31, 2023 at 9:00 pm in reply to: Unable to start communication lines because the configuration database is not re #12346TDE
ParticipantBut the problem is still present
TDE
No I’m new user of rapid Scada I only working locally.
