Can we write a code to added a push bottom to the scheme Editor?
Can u tell me how to configure one bottom to activate two tags in a time where the first should be disactivated ones we release the bottom, and the second tag stay activated for 15 s ?
This topic was modified 3 years, 7 months ago by Mikhail.
Using Automatic Control Module you can send 2 commands triggered by a one command.
Button component can send command on click. There is no a release button handler.
We tried to send two commands in the same time (with one button) but it seems there is a delay between the status changes of the two tags (When the condition of the channel tag is correct the command to activate the 2nd tag will be sent after almost 1s).
