victorlamParticipantHello,
I have installed 6.0.0. May I know how can I install the 6.1.0?
or I need to uninstall the whole version?
victorlamParticipantHello Han Hoang,
Nice to talk with you I also would like to use gmail or other email account to get the notification. Can you share your steps or procedures or do you need to purchase any plug in so that it is successful now?
THanks for your help and support.
Can you kindly help to show some pictures about the extra scheme components for editor application?
I would like to learn to use email sending to remind the user.
Can you help to share some settings how you can configure here?Thanks!!
Victor
Do you mean to leave all channel data type blank in the box?
May I know the reason for stating the formula as double not to use int as a simple one?
I found one file ScadaComm.en-GB with the product name. But I cannot save as mentioned with no permission. Or I can amend the product name via Administator side.
victorlamParticipantHello,.
For severity, I see there are many values, like 1, 500, 750. Can you kindly help to clarify further? What will be the level of range for severity?
Is this ranged from 1 to 750? or 1/500/750 as an option?
Noted.
Understood.
I am seening that there is plugin for event acknowledgeent and notification management plugin. Can I use this notification management plug in temporarily before the release of V6 at the moment?
I mean the Chartpro plug in and if possible notificaton also.
Thanks for the reply.
Then at the Webstation, it will be for browsing only and all the configuration and set up must be done via Administrator including the previous plug in authorization.
You mean that notification plugin is only valid for 5.84 version. What will be the schedule on V6 if planned?
Please advise if the formula was named as script now?
victorlamParticipantHere is the screenshot for the review:-
https://drive.google.com/file/d/1QaZfTGylorUIRyAlql8slJeTVnaFNPi0/view?usp=share_link
