Jure
ParticipantNow one formula is working, but it doesn’t execute just once, but whole time. So – operator works, but / doesn’t work.
I hope that you can see all three images: device, channels and web browser view.
This reply was modified 5 years, 6 months ago by
Jure.
Jure
ParticipantFrom the last time I was able to make MQTT working. Data and commands are successfully transferred. But I have another question. Is it possible to use formulas for input channels that are using MQTT? Or should I use formulas inside mqtt.xml file? And how is with events and alarms?
Jure
ParticipantCorrect, it waits because 192.168.95.112 is offline. But because of that 192.168.95.10 is unresponsive.
I hope that properties work now:
http://imgur.com/a/mV5s7a3Jure
ParticipantSorry second screenshot was wrong:
https://imgur.com/a/XnMcZ6SJure
ParticipantSettings:
https://imgur.com/Oz20xiYCommunication log:
https://imgur.com/TeDtNY0As you can see it takes 25 seconds between two reads. But it should read every second. So if I send command in this 25 second window it won’t be sent. Should every device be on it’s own line?
This reply was modified 5 years, 7 months ago by
Jure.
Jure
ParticipantIf you look at last line it says:”Establish a TCP connection with 192.168.95.112:502″ it is waiting there for few seconds without communicating with other device which is still turned ON.
With turning off the device i mean turning off the simulator on some PC. Other device that is PLC is still working.With communication channel you mean this?
http://imgur.com/a/motJS49Jure
ParticipantI have similar problem. If I connect to broker trough client it works, but if I try to set up connection in Rapid SCADA I get same error. I followed youtube tututorial.
Jure
ParticipantIt was my error. I opened with editor file in SCADA/Interfaces instead inside the project. So when I saved the file it would show changes on website. But when I built the project again and uploaded it to server it has overwritten changes.
Jure
ParticipantI understand now what is the problem, i was editing files in interface which is built from project/interface.
Jure
ParticipantIt must be something else, I crated new elements by hand and they again disappeared on upload.
Jure
ParticipantWell I didn’t know that it is automatically cleared and this is just a test project, so that we can see if this software fits our needs.
I managed to find the reason for problem:
If I copy elements from interface 1 to interface 2 and save interface 2, everything is ok.
But if I upload whole project, then all copied elements will get deleted. Even if I copy copied element. And since I wanted my elements to look the same in interface 2 as in interface 1 all elements were copies.
Is it possible to fix this? Because it easier to build new interface if you can copy elements from existing interface, especially if you want them to have same design.Jure
ParticipantI recreated the interface and everything was OK. I made backup copy for both of my interfaces inside the “Inteface” folder.. After that I made some changes in administrator and uploaded complete project and interface was overwritten again. Besides that both backups were deleted.
is it possible that there is huge bug or am i doing something wrong?Jure
ParticipantI don’t have the old interface anymore. Because when I made changes I saved them to the same interface file.
Jure
ParticipantI tried sending to specific email but I get same error.
Version of .dll is 5.0.4.0.Jure
ParticipantThis is how the interface currently looks:
https://imgur.com/a/WvMuQ6BBefore I had around 30-50 elements on interface. But when I uploaded new version of interface it reverted to old one.
Before it looked similar to this:
https://imgur.com/a/OgQJ2oeLike I said before, element disappeared when I uploaded new version of interface.
