quintelosky
Viewing 15 posts - 16 through 30 (of 53 total)
  • in reply to: Api connection #13432
    quintelosky
    Hi
    Ok, I changed the port but I continue with problems:
    https://ibb.co/m4rjt9Y
    in reply to: Events and Ack #13391
    quintelosky
    Hi
    Well, for the moment, I created a program that read eventsxxxx.dat and check if exists an event with ack requeriment but no ack.
    The program create a file with the channel number name and the scada, in a new tag, check if a file with the name exists
    With that I can know if an event is ack
    https://ibb.co/fQV3v0L
    https://ibb.co/yVxPVm4
    https://ibb.co/v3KYCBC
    in reply to: Don’t display some events #13390
    quintelosky
    Hi
    I created a script to force channel status
    https://ibb.co/hsf4K0b
    https://ibb.co/LDwh6sP
    And nothing. Is it possible that tag data type affect?
    https://ibb.co/0sC86FC
    If I create a new tag ‘calculated’ with formula Val(10436) and limits, works fine the new tag
    in reply to: Events and Ack #13302
    quintelosky
    Hi
    I don’t have the knowledge (and I don’t have time either)
    Can you put this in the wish list? I think a function to check if a cnl have ack event (Where I can view the progress of the wish list?)
    Many thanks Mikhail
    in reply to: Events and Ack #13292
    quintelosky
    If you need to check all existing events associated with a channel, it’s possible, but may slow down the performance.
    And How can I do that?
    Many thanks
    in reply to: Events and Ack #13283
    quintelosky
    Yes, we want this
    in reply to: Events and Ack #13282
    quintelosky
    Hi
    I’m using v6
    in reply to: Error calling the GetCurDataByView #12963
    quintelosky
    Hi
    Sorry for the delay
    I changed 10000 port to 9999, and now works fine.
    in reply to: Error calling the GetCurDataByView #12888
    quintelosky
    Hi
    I disconnect lan, restart all, and continue the error
    scadaweb.log:
    2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Webstation 6.1.0.0 started
    2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dll
    2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgChart 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
    2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgMain 6.0.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
    2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgScheme 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
    2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgSchBasicComp 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
    2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgWebPage 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
    2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
    2023-06-28 12:18:16 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
    2023-06-28 12:18:17 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
    2023-06-28 12:18:19 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
    Incorrect format of data received from the server: unable to read data packet header
    2023-06-28 12:18:27 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
    2023-06-28 12:18:29 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
    2023-06-28 12:18:37 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
    2023-06-28 12:18:39 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
    2023-06-28 12:18:47 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
    2023-06-28 12:18:49 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
    2023-06-28 12:18:57 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
    2023-06-28 12:18:59 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
    2023-06-28 12:19:07 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
    2023-06-28 12:19:09 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
    2023-06-28 12:19:17 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
    2023-06-28 12:19:19 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
    2023-06-28 12:19:27 [TCRLPLNETAP][TCRLPLNETAP$][ACT] Receive the configuration database
    2023-06-28 12:19:29 [TCRLPLNETAP][TCRLPLNETAP$][ERR] Error checking server connection:
    in reply to: Separate Event view #12825
    quintelosky
    Hi
    Works fine, you are a genius
    Many thanks
    in reply to: Separate Event view #12813
    quintelosky
    Hi
    Yes, we have multiple monitors and we want put events in one screen, main view in other, graphs in other
    in reply to: Select tags to postgresql #12798
    quintelosky
    Hi
    Solved (using archive mask and archive by default options)
    in reply to: Modbus error – maintain values #12787
    quintelosky
    Many thanks
    in reply to: OPC Ua error #12768
    quintelosky
    Many thanks
    Works fine
    in reply to: OPC Ua error #12766
    quintelosky
    Hi
    Yes, but I found a problem
    DrvOpcUa.Logic.xml is overwritten with default values, and the error continues.
    If I edit drvopcua.logic, communication works fine. But, when I upload a new configuration, I lost communication and I need edit the file.
    How can I do to mantain in DrvOpcUa.Logic.xml the new changes? (I put only-read attribute but I have an error when upload a new configuration)
