Artos9
Viewing 15 posts - 16 through 30 (of 39 total)
  • in reply to: Internal server error (500) #8125
    Artos9
    in reply to: Table View transposition & max present tavle values #8121
    Artos9
    Thanks you for description.
    Unfortunately page return Error HTTP 404.7.
    ElasticRepExample.xml:1 Failed to load resource: the server responded with a status of 404 (Not Found)
    Interface settings.
    https://imgur.com/S2RQRG9
    in reply to: Internal server error (500) #8118
    Artos9
    After logging I see more errors.
    https://ibb.co/M9Xz2VR
    in reply to: Internal server error (500) #8117
    Artos9
    Error message from console.
    https://imgur.com/UIUbE3Z
    in reply to: Internal server error (500) #8106
    Artos9
    Below you can find a server logs.
    https://imgur.com/QQLjEwL
    in reply to: Table View transposition & max present tavle values #8074
    Artos9
    Elastic Report plugin works correctly.
    In link you can find modified report table.
    https://imgur.com/xVLRs5I
    Is possible to think about more complicated Table plugin in future with custom views (transposition, hour, minute table header, wider date selection)?
    in reply to: ScadaComm error #8052
    Artos9
    I’m not sure, that I understand the idea.
    Scada is installed on Remote Linux server (http://mywebserverexample.com/scada), as WebServer is Apache.
    But additionaly Scada is configureted in cooperation with localhost.
    I’m sorry for misunderstanding Web&Server administrations is new for me.
    in reply to: Internal server error (500) #8051
    Artos9
    I use Debian 4.19, this is Remote server without GUI.
    Yes, if I open server URL (prefix http), Apache website is visible.
    in reply to: ScadaComm error #8036
    Artos9
    I see that ScadaWeb and ScadaServer are working still on ‘localhost’, is it correct? In case of Scada installation of my Linux server?
    ScadaWeb.log
    2021-01-15 16:07:03 <shm2><www-data><ACT> Initialize common web application data
    2021-01-15 16:07:03 <shm2><www-data><ACT> Connect to SCADA-Server “localhost”
    2021-01-15 16:07:03 <shm2><www-data><ACT> Refresh the tables of the configuration database
    2021-01-15 16:07:03 <shm2><www-data><ACT> Fill input channels properties
    2021-01-15 16:07:03 <shm2><www-data><ACT> Fill output channels properties
    2021-01-15 16:07:03 <shm2><www-data><ACT> Fill input channel statuses properties
    ScadaServerSvc.log
    2021-01-15 15:54:27 <shm2><root><ACT> ScadaServerService 5.1.4.1 is started
    2021-01-15 15:54:27 <shm2><root><ACT> Check the existence of the data directories is completed successfully
    2021-01-15 15:54:27 <shm2><root><ACT> Check the existence of the configuration database files is completed successfully
    2021-01-15 15:54:27 <shm2><root><ACT> Input channels are read from the configuration database. Active channel count: 10
    2021-01-15 15:54:27 <shm2><root><ACT> Ouput channels are read from the configuration database
    2021-01-15 15:54:27 <shm2><root><ACT> Users are read from the configuration database
    2021-01-15 15:54:27 <shm2><root><ACT> Formulas are read from the configuration database
    2021-01-15 15:54:27 <shm2><root><ACT> The formulas source code has been compiled
    2021-01-15 15:54:27 <shm2><root><ACT> Connection listener is started
    2021-01-15 15:54:27 <shm2><root><ACT> Start server
    2021-01-15 15:54:27 <shm2><root><ACT> Current data are loaded
    2021-01-15 16:02:40 <shm2><root><ACT> Connect to client 127.0.0.1
    2021-01-15 16:02:40 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
    2021-01-15 16:02:40 <shm2><root><ACT> Check username and password for admin. Result: passed
    2021-01-15 16:02:45 <shm2><root><ACT> Connect to client 127.0.0.1
    2021-01-15 16:02:45 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
    2021-01-15 16:02:50 <shm2><root><ACT> Connect to client 127.0.0.1
    2021-01-15 16:02:50 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
    2021-01-15 16:02:55 <shm2><root><ACT> Connect to client 127.0.0.1
    2021-01-15 16:02:55 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
    2021-01-15 16:03:02 <shm2><root><ACT> Connect to client 127.0.0.1
    2021-01-15 16:03:02 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
    2021-01-15 16:03:09 <shm2><root><ACT> Connect to client 127.0.0.1
    2021-01-15 16:03:09 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
    2021-01-15 16:03:40 <shm2><root><ACT> Disconnect client 127.0.0.1
    2021-01-15 16:03:45 <shm2><root><ACT> Disconnect client 127.0.0.1
    2021-01-15 16:03:50 <shm2><root><ACT> Disconnect client 127.0.0.1
    2021-01-15 16:03:56 <shm2><root><ACT> Disconnect client 127.0.0.1
    2021-01-15 16:04:03 <shm2><root><ACT> Disconnect client 127.0.0.1
    2021-01-15 16:04:09 <shm2><root><ACT> Disconnect client 127.0.0.1
    2021-01-15 16:06:38 <shm2><root><ACT> Connect to client 127.0.0.1
    2021-01-15 16:06:38 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
    2021-01-15 16:06:44 <shm2><root><ACT> Check username and password for admin. Result: passed
    2021-01-15 16:06:48 <shm2><root><ACT> Connect to client 127.0.0.1
    2021-01-15 16:06:48 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
    2021-01-15 16:06:56 <shm2><root><ACT> Connect to client 127.0.0.1
    2021-01-15 16:06:56 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
    2021-01-15 16:07:03 <shm2><root><ACT> Connect to client 127.0.0.1
    2021-01-15 16:07:03 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
    2021-01-15 16:07:44 <shm2><root><ACT> Disconnect client 127.0.0.1
    2021-01-15 16:07:49 <shm2><root><ACT> Disconnect client 127.0.0.1
    2021-01-15 16:07:56 <shm2><root><ACT> Disconnect client 127.0.0.1
    2021-01-15 16:08:03 <shm2><root><ACT> Disconnect client 127.0.0.1
    in reply to: ScadaComm error #8034
    Artos9
    You should check its log. Make sure that you changed server directories in the project before uploading (Server – Common Parameters).
    Yes, I change it.
    ScadaServer logs.
    2021-01-15 08:04:23 <shm2><root><ACT> ScadaServerService 5.1.4.1 is started
    2021-01-15 08:04:23 <shm2><root><ACT> Check the existence of the data directories is completed successfully
    2021-01-15 08:04:23 <shm2><root><ACT> Check the existence of the configuration database files is completed successfully
    2021-01-15 08:04:23 <shm2><root><ACT> Input channels are read from the configuration database. Active channel count: 10
    2021-01-15 08:04:23 <shm2><root><ACT> Ouput channels are read from the configuration database
    2021-01-15 08:04:23 <shm2><root><ACT> Users are read from the configuration database
    2021-01-15 08:04:23 <shm2><root><ACT> Formulas are read from the configuration database
    2021-01-15 08:04:24 <shm2><root><ACT> The formulas source code has been compiled
    2021-01-15 08:04:24 <shm2><root><ACT> Connection listener is started
    2021-01-15 08:04:24 <shm2><root><ACT> Start server
    2021-01-15 08:04:24 <shm2><root><ACT> Current data are loaded
    ScadaServer Settings.
    <ScadaServerSvcConfig>
    <!–Common Parameters–>
    <CommonParams>
    <Param name=”TcpPort” value=”10000″ descr=”TCP port number” />
    <Param name=”UseAD” value=”false” descr=”Use Active Directory for users authentication” />
    <Param name=”LdapPath” value=”LDAP://server” descr=”Domain controller server path” />
    <Param name=”DetailedLog” value=”false” descr=”Write detailed information to the log” />
    </CommonParams>
    <!–Directories–>
    <Directories>
    <Param name=”BaseDATDir” value=”/opt/scada/BaseDAT/” descr=”The configuration database in DAT format directory” />
    <Param name=”ItfDir” value=”/opt/scada/Interface/” descr=”The interface directory” />
    <Param name=”ArcDir” value=”/opt/scada/ArchiveDAT/” descr=”The archive in DAT format directory” />
    <Param name=”ArcCopyDir” value=”/opt/scada/ArchiveDATCopy/” descr=”The archive copy in DAT format directory” />
    </Directories>
    <!–Saving Parameters–>
    <SaveParams>
    <Param name=”WriteCurPer” value=”1″ descr=”Current data writing period, sec” />
    <Param name=”InactUnrelTime” value=”5″ descr=”Unreliable on inactivity, min” />
    <Param name=”WriteCur” value=”true” descr=”Write current data” />
    <Param name=”WriteCurCopy” value=”true” descr=”Write current data copy” />
    <Param name=”WriteMinPer” value=”60″ descr=”Minute data writing period, sec” />
    <Param name=”StoreMinPer” value=”365″ descr=”Minute data storing period, days” />
    <Param name=”WriteMin” value=”true” descr=”Write minute data” />
    <Param name=”WriteMinCopy” value=”true” descr=”Write minute data copy” />
    <Param name=”WriteHrPer” value=”60″ descr=”Hourly data writing period, min” />
    <Param name=”StoreHrPer” value=”365″ descr=”Hourly data storing period, days” />
    <Param name=”WriteHr” value=”true” descr=”Write hourly data” />
    <Param name=”WriteHrCopy” value=”true” descr=”Write hourly data copy” />
    <Param name=”StoreEvPer” value=”365″ descr=”Events storing period, days” />
    <Param name=”WriteEv” value=”true” descr=”Write events” />
    <Param name=”WriteEvCopy” value=”true” descr=”Write events copy” />
    </SaveParams>
    <!–Modules–>
    <Modules />
    </ScadaServerSvcConfig>
    in reply to: Table View transposition & max present tavle values #8027
    Artos9
    Then use WebPageView to show the report in the explorer tree. I can provide more details if needed.
    If you could it will be very helpful.
    in reply to: Transfer File from Computer to Rpi #7913
    Artos9
    Thanks you. It’s clear.
    I know how to create new deployment profile, but set parameters correctly aren’t clearly.
    in reply to: Transfer File from Computer to Rpi #7906
    Artos9
    Hi Mr Mikhail,
    I searched all forum topic, but I haven’t find more information how to upload project to Raspberry Pi created on Windows.
    Is possible to upload directly from Windows OS to Raspberry Pi Apache server(localhost)?
    Thank you so much
    • This reply was modified 5 years, 9 months ago by Artos9.
    in reply to: Database MySQL usage #7680
    Artos9
    I would like to ask about Database data size import. I have seen that max size on text format is 8 char’s. Is something wrong with my settings?
    https://imgur.com/9nlHqUk
    in reply to: Users, roles, rights #7602
    Artos9
    SCADA Server looks OK.
    2020-11-26 00:12:56 <DESKTOP-2LTOEHA><SYSTEM><ACT> ScadaServerService 5.1.4.0 is started
    2020-11-26 00:12:56 <DESKTOP-2LTOEHA><SYSTEM><ACT> Check the existence of the data directories is completed successfully
    2020-11-26 00:12:57 <DESKTOP-2LTOEHA><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
    2020-11-26 00:12:57 <DESKTOP-2LTOEHA><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 12
    2020-11-26 00:12:57 <DESKTOP-2LTOEHA><SYSTEM><ACT> Ouput channels are read from the configuration database
    2020-11-26 00:12:57 <DESKTOP-2LTOEHA><SYSTEM><ACT> Users are read from the configuration database
    2020-11-26 00:12:57 <DESKTOP-2LTOEHA><SYSTEM><ACT> Formulas are read from the configuration database
    2020-11-26 00:12:57 <DESKTOP-2LTOEHA><SYSTEM><ACT> The formulas source code has been compiled
    2020-11-26 00:12:57 <DESKTOP-2LTOEHA><SYSTEM><ACT> Connection listener is started
    2020-11-26 00:12:57 <DESKTOP-2LTOEHA><SYSTEM><ACT> Start server
    2020-11-26 00:12:57 <DESKTOP-2LTOEHA><SYSTEM><ACT> Current data are loaded
    2020-11-26 00:12:57 <DESKTOP-2LTOEHA><SYSTEM><ACT> Connect to client 127.0.0.1
    2020-11-26 00:12:57 <DESKTOP-2LTOEHA><SYSTEM><ACT> The user ScadaComm is successfully authenticated
    2020-11-26 00:13:09 <DESKTOP-2LTOEHA><SYSTEM><ACT> Connect to client 127.0.0.1
    2020-11-26 00:13:09 <DESKTOP-2LTOEHA><SYSTEM><ACT> The user ScadaWeb is successfully authenticated
    AdvancedDashboard.xml exist and is in correct folder.
