kcks66
ParticipantHi Mikhail,
Currently output channel has no any formula.
kcks66
ParticipantHi manjey73,
You meant write a scripts to convert decimal numbers to hexadecimal numbers in the output channel?
I am weak in scripting. Any idea how to do it?
kcks66
I change to use Cmd and it’s worked.
Thank you.kcks66
Yes. This is the format I want. Looking forward for the migration program from 5.8.4 to 6.1.X.
kcks66
It is worked. Thank you.
kcks66
I want to send out email alert when the device offline resume from ‘—‘ back to online with ‘number’.
I tried to set channel status to 1, but it doesn’t work.
Pls advice and thank you.kcks66
Email was successfully sent out by simple text.
Thank you.kcks66
Thanks for the Yandex setting. I tested by using Communicator Email Command, it went through but Yandex treat it as spam.
Error sending email to cho.keat.seong@gmail.com: Transaction failed. The server response was: 5.7.1 Message rejected under suspicion of SPAM; https://ya.cc/1IrBc 1655471924-o4ZxzWO5VS-IgMqIU61
kcks66
Port 25 gave another new error message:
Error sending email to cho.keat.seong@gmail.com: Bad sequence of commands. The server response was: 5.5.4 Error: send AUTH command first. 1655372643-0Hlz4rXRDy-i3MmpLEF
kcks66
Noted that I should use another email service. I setup an account from yandex email service as per your suggest.
However, I couldn’t make the email sender work; I got error message:
My email sender setting:
Pls advice for is there anything else I need to do?
Thank you.kcks66
ParticipantHi Mikhail, manjey73 & JW,
It worked. Thank you.
kcks66
Noted. Will try Rapid SCADA 6.
kcks66
As for reading which always updating I managed to get one data at one minute as below:
As for reading which has no always updating at every one minute as below:
Is there any possibility to made the export data above still maintain export data at one minute?
Example:
25-Apr-22 14:01:00 123456
25-Apr-22 14:02:00 123456
25-Apr-22 14:03:00 123456
25-Apr-22 14:04:00 123460
25-Apr-22 14:05:00 123460Thank you.
kcks66
Participantkcks66
