Duplicate data by EXPORT TO DATABASE module
Forum Home › Forums › Understanding the Software › Duplicate data by EXPORT TO DATABASE module
  • #10197
    kcks66
    Hi Mikhail,
    I configured sampling interval at one minute as below:
    https://ibb.co/Kj5qHPQ
    However, I got data duplicated in my database as below:
    https://ibb.co/V9wPGVR
    My Export To Database module configuration as below:
    https://ibb.co/Rv1cGxF
    https://ibb.co/S7z7w4S
    Pls advice and thank you.
    #10198
    Communicator also sends all data periodically. You can disable this in the common parameters of Communicator.
    I also suggest to try Rapid SCADA 6 Beta which support PostgreSQL archives work clearly.
    #10201
    kcks66
    Hi Mikhail,
    https://ibb.co/vc73095
    Pls advice for how to disable the option?
    #10205
    Set Period of sending all device tags to 0. Communicator will send changes only.
    #10210
    kcks66
    Hi Mikhail,
    As for reading which always updating I managed to get one data at one minute as below:
    https://ibb.co/QkXTpcT
    As for reading which has no always updating at every one minute as below:
    https://ibb.co/yqFZwk5
    Is there any possibility to made the export data above still maintain export data at one minute?
    Example:
    25-Apr-22 14:01:00 123456
    25-Apr-22 14:02:00 123456
    25-Apr-22 14:03:00 123456
    25-Apr-22 14:04:00 123460
    25-Apr-22 14:05:00 123460
    #10214
    It is implemented out of the box in Rapid SCADA 6 for PostgreSQL. I suggest you to try the new version.
    #10221
    kcks66
    Hi Mikhail,
    Noted. Will try Rapid SCADA 6.
    #10223
    I expect questions when you start with the v6. Ask here on the forum with a note that a question is about v6.
