yotool
Viewing 15 posts - 16 through 30 (of 38 total)
  • in reply to: Dashboard Plug Issue Using xml File #13377
    yotool
    in reply to: Installing Licensed Plugins in v.6.1 Beta #13361
    yotool
    Many thanks Mikhail.
    …making good progress in instantiating v.6.1 beta as an upgrade from an existing Rapid SCADA v.5.8 installation..
    Using the new v.6.1 documentation you kindly provided, I was able to successfully install both the “Dashboard” and “Chart Pro” plugins.
    …was also able to successfuly install the 30-day trial registration codes for both the plugins within the “Administrator” application.
    Copied the “Dashboard1.xml” “View” that is included with the “Dashboard” plugin (which references the Chart Pro object). The “Dashboard1.xml” file content references existing/working “Channels” from the “Simulator” device.
    “Uploaded” the modified project…
    All services were then “Restarted” successfuly.
    However, when I attempt to open the included/default “Dashboard” “View” in the browser, the mouse pointer displays a red circle with a diagonal-dash through it.
    The “Dashboard” (.xml) view is View #7.
    If I change the browser URL directly to http://scadaservername:10008/View/7, the browser responds with “Unable to resolve View Specification”.
    Almost there using v.6.1…
    ** What am I missing now???
    • This reply was modified 3 years, 2 months ago by yotool.
    in reply to: Installing Licensed Plugins in v.6.1 Beta #13347
    yotool
    I found this:
    https://forum.rapidscada.org/?topic=plugin-install-no-activation-in-web
    It seemed to work for the “Dashboard” plugin, but when attempting to add the “Chart Pro” plugin using the very same technique in v.6.1, I never see the ChartPro plugin in the Administrator/Project/Instances/Default/Webstation/Plugins list.
    in reply to: New release Rapid SCADA 6.1.x #13338
    yotool
    …when preserving the directory hierarchy during unzipping, the v.6.1.2 compatible dlls are not being placed into the C:\Program Files\SCADA\ScadaServer\Mod directory.
    The zip file content is only pointing to the …/ScadAdmin, …/ScadWeb, and … Views directories.
    in reply to: New release Rapid SCADA 6.1.x #13337
    yotool
    Sorry for all of my recent questions on Rapid SCADA beta 6.1…
    The current documentation for installing plugins (in my case Dashboard and Chart Pro) is not up to date for v.6.1.
    I tried the recommended procedure for installing optional plugins referenced at:
    https://rapidscada.net/docs/en/5.8/installation-and-run/module-installation#plugins
    but it appears that this document is no longer accurate for v.6.1.
    In version 6.1, how do I install these license-required modules?
    If I use the existing procedure (even changing the referenced “C:\SCADA” to “C:\Program Files\SCADA”), when I open the “Administrator” application in v.6.1 and go to Instances/Default/Server/Modules, I do not see any new “Unused” modules which were unzippped with their directory hierarchy preserved from the “unzip” process).
    Thanks for the assistance.
    in reply to: New release Rapid SCADA 6.1.x #13333
    yotool
    In the “Communicator”/Line Oprions/Device Polling/Properties/Element Group/Element configuration, it appears that the element “Tag Codes” cannot contain the underscore “_” character?
    The dash “-” seems to work OK.
    If an uderscore is used in a “Tag Code”, the device “Elements” do not properly register as a “Channel”.
    Is that correct?
    Thanks.
    in reply to: New release Rapid SCADA 6.1.x #13331
    yotool
    Thanks Mikhail.
    For the “Server” functionality question, I was not referring ro READing the historial data, but EDITING the existing minute/hourly data as available in the older “server” stand-alone application.
    I believe that you were formerly using MS SQL Server Express for the database?
    It’s nice that there are now different storage-engine options in v 6.1.
    ** Where are the selections for various “storage engines” selected and configured?
    in reply to: New release Rapid SCADA 6.1.x #13324
    yotool
    ** Also for v.6.1 beta there seems to be no “Save” button when editing the objects in the Scada “Administrator” application
    It seems like one must hit the “Close” (X) Window button and then a prompt for “Save Changes Yes/No” appears and one can then choose “Save”.
    Woops, I see that is in the far upper-left of the main “Administrator” Application Window.
    in reply to: New release Rapid SCADA 6.1.x #13323
    yotool
    ** Where is the “Server” application in SCADA v.6.1?
    How can one manipulate the historical data in a similar fashion to the previous Rapid SCADA versions?
    Thanks as always Mikhail.
    in reply to: New release Rapid SCADA 6.1.x #13322
    yotool
    *** Is there any documentation for Rapid SCADA v.6.1?
    It seems like there are changes to the way that device-“Channels” are assoicated with communication line entities.
    No matter how many times I defined (and re-defined) “channel” information, it would never retrive the channel data from the communicator module.
    …finally discovered that the “join” between the “channel” definition is the matching “tag code” in the communicator module.
    Thanks for including the “Simulator” objects in the default project template.
    That ulitimately allowed me to compare every subtle difference in “my” device-channel definitions to the working “simulator” equivalents.
    yotool
    Sorry…
    I can be stupid at times.
    Although I had the “Windows Firewall” via “Firewall and Network Protection” DISABLED.
    The “Window Defender Firewall” was lacking/blocking incoming PERMIT rules for port 10008 (of course).
    …maybe others can learn from my mistake :>)
    in reply to: ChartPro Maximum Display Period #11755
    yotool
    I see this is a very old thread, but does there now, in any way, exist the possibility to have the excellent Chart Pro plug-in historical capability to increase beyond the hard-coded 32 day time-period?
    It would be very useful in some situations.
    ..like the idea of using the “hourly” summary data to save data retention storage requirements in SQL Server Express for time periods in excess of the current 32-day maximum time-span of the charts.
    in reply to: Communication Line Request Sequence not Saving #7897
    yotool
    Yes, agreed but then we are back to the beginning of the issue where this “not saving/associating the Request-Sequence XML file (template) with a device” problem appears to exist with the “latest” version v5.8.2 of Rapid SCADA.
    If anything, just curious to know if you can reproduce the issue I am seeing in v.5.8.2.
    Thanks.
    in reply to: Communication Line Request Sequence not Saving #7878
    yotool
    Acknowledged.
    I could not find any way to easily determine which version of Rapid SCADA is installed. Might be nice to have the “About” feature of the Administrator application show the versions of the overall product as wells as the modules. Just a thought.
    In any case. I DO have the latest version of Rapid SCADA installed and this does appear to be a bug in version 5.8.2. Would be interested to know if you, or another, can replicate the issue on your end.
    I UNinstalled v.5.8.2, INSTALLED 5.7.1, which I had downloaded some time ago, and the problem is gone.
    Many thanks.
    in reply to: Communication Line Request Sequence not Saving #7854
    yotool
    Sorry, it appears that I DID download and install the latest version of Rapid SCADA 5.8, but when I looked for the version I had installed before posting this issue, I used the “About” button for the “Administrator” sub-application which displays 5.5.2.0.
    The installer/uninstaller does show v.5.8.
    • This reply was modified 5 years, 11 months ago by yotool.
