Viewing 15 posts - 1,186 through 1,200 (of 6,289 total)
  • in reply to: Rapid SCADA IoT #14312
    Could you draw a simple diagram that shows the architecture of your system?
    in reply to: Convert historical data from V5 to V6 #14311
    2) In Elastic Report, use SelectArchive and/or DefaultArchive
    3) Yes. Activate archives that are in use.
    in reply to: Convert historical data from V5 to V6 #14310
    1) Create a copy of ChartPro.xml, for example, PlgChartPro_Profile2.xml
    Add a new line into ChartPro_Config.xml
    <Profile fileName="PlgChartPro_Profile2.xml">Profile 2</Profile>
    in reply to: How to write value and appear on the screen? #14305
    To allow a user setting a channel value, create a channel of the Calculated/Output type, and set it’s output formula to SetData()
    DynamicText will show the current value of the channel.
    in reply to: Convert historical data from V5 to V6 #14304
    > Those .dat files from v5 I used the converter to convert to v6 .dat files format, can be trend by modArcBasic only, right?
    Yes.
    > what should I do after I set ModArcPostgreSql as my main achieve and still can trend back those converted historical data previously from v5?
    Using Chart Pro, you can create a chart profile to open data from *.dat archive. Reports also support choosing an archive.
    However, may be in your case it is better to use PostgreSQL as a secondary archive.
    in reply to: Convert historical data from V5 to V6 #14299
    Try the updated converter. Send a screenshot of its work, please.
    in reply to: Current Data sudden become Not Ready #14298
    That’s good! Thank you for the info.
    in reply to: Rapid SCADA IoT #14297
    Google Cloud, Microsoft Azure, AWS, Digital Ocean and many others.
    You need a Linux-based virtual machine.
    Deployment profile will help to control your Rapid SCADA instance remotely.
    in reply to: Convert historical data from V5 to V6 #14291
    It is important to find the cause of the error. May be those files contains correct and useful data. Could you open the problem files in the Administrator app to view data and try to realize why they can cause the error?
    in reply to: New release Rapid SCADA 6.2.x #14283
    Rapid SCADA 6.2.1 has been released.
    The release contains error fixes, as well as a new module Difference Calculator (ModDiffCalculator), which is useful for calculating consumption for a period.
    in reply to: jQuery issues in #14276
    RenderContext is created here.
    imageMap is initialized here.
    in reply to: Convert historical data from V5 to V6 #14275
    You should run cmd first. Then execute the *.exe in the command prompt.
    in reply to: Webserver issues on win 11 #14274
    What error do you get when open http://localhost:your_port ?
    Does the above help?
    in reply to: Webserver installation isssues #14272
    First of all, check that AspNetCoreModuleV2 is installed as shown here.
    in reply to: How to install Rapid SCADA on ubuntu server ? #14268
    Messages related to the competitive software will be deleted. To solve an issue, please ask certain questions providing logs and screenshots.
