MikhailModeratorFind ExtExternalTools in the Administrator options, and configure the extension properties.
I am also interested in the possibility of creating a pure CSV file without an XML header.
Could you provide an example of the existing file you get and a file you need?
Is it possible, like the other plugins, to integrate the function into the frontend
In the modern Administrator app, there is ExtExternalTools extension. Using this extension, you can add custom command to run command line utilities from the UI.
MikhailModeratorA project may include many instances running on different computers.
According to the manual,
“An instance is a set of Rapid SCADA applications running the same project and installed on the same computer.”December 27, 2024 at 9:22 am in reply to: Unable to communicate with the device [4] TestDev because connection is not est #15848
Possible cause is that the communication channel is not configured. Please provide screenshots of the communication line main options.
You can set directories in the archive properties.December 26, 2024 at 8:45 am in reply to: How to control LED flashing through the digital output(DO) port #15844
MikhailModeratorSo, you can send a command from Rapid SCADA to the device. Commands can be send using the Administrator application and the web interface.
December 26, 2024 at 8:43 am in reply to: Unable to communicate with the device [4] TestDev because connection is not est #15843
Please provide a communication line log.December 25, 2024 at 12:12 pm in reply to: How to control LED flashing through the digital output(DO) port #15839
Have you configured communication between the DO module and Rapid SCADA?
*.scss files are complied to *.min.css. You should change *.min.css.
CSS files are located in ScadaWeb\wwwroot\css
Use the developer tools in the browser to find a certain CSS file.-
This reply was modified 1 year, 5 months ago by
Plugin for event acknowledgement should be PlgMain.
The notification panel width is specified in CSS files.
MikhailModeratorHi Rodrigo,
Your question is about MQTT, not related the current topic of displaying strings.
Please start a new topic to discuss the question. Provide screenshots of the MQTT configuration and logs.
MikhailModeratorThe application is not ready, Try again later
Check ScadaWeb.log and ScadaServer.log for the error details.
This reply was modified 1 year, 6 months ago by
MikhailModeratorIn that case, does the previous password work?
