How to control LED flashing through the digital output(DO) port
Forum Home › Forums › Understanding the Software › How to control LED flashing through the digital output(DO) port
  • #15837
    38368423
    #15839
    Have you configured communication between the DO module and Rapid SCADA?
    #15840
    38368423
    yes, I have.
    #15844
    So, you can send a command from Rapid SCADA to the device. Commands can be send using the Administrator application and the web interface.
    #15859
    詹森
    How can I achieve the led flashing state in the automatic control module? That is, when the led display mode is blinking, the automatic control module controls the led flashing,Thanks, respect
    #15863
    For example, if some channel value > 0, the module can send commands to switch a led. Use a channel data trigger for this purpose.
