Viewing 15 posts - 6,241 through 6,255 (of 6,279 total)
  • in reply to: Using variables on SCADA-Scheme Editor #175
    I understand your idea. To be honest, I had the same thoughts. But it is not supported. The other approach is preferable. Most likely SCADA-Web would contain a system of visual components those implement dynamics.
    in reply to: Communication delay with server #174
    How did you measure the delay?
    in reply to: Internal variables #170
    You can reset this kind of value by using Generator of SCADA-Server. But it is not suitable for your case. I think the best way of implementing the functionality you need is defining your own formula that calculates switching and supports reset.
    in reply to: SCADA-Scheme Editor does not work #168
    Could you upload your screenshot to the web using image hosting, for example, postimage.org ? I can’t view the image from drive D of your PC.
    in reply to: Output command value #159
    No formula is needed for sending Off and On.
    Have you got a message “The command is in the queue for execution” from SCADA-Web?
    Probably you didn’t click Execute button after selecting command value.
    You can change command radio buttons to buttons in this web form using SCADA-Web Configurator (Simple commands sending checkbox).
    in reply to: Installation errors #137
    Please check that the directories specified in SCADA-Server
    and shown here are exist.
    Did you install Rapid SCADA in C:\SCADA directory?
    • This reply was modified 11 years, 2 months ago by Mikhail.
    in reply to: Scada-Web not install on WinXP #134
    For the reason that XP is outdated OS, SCADA-Web can’t be installed automatically. Manual installation of SCADA-Web is needed. Follow the steps described in Doc\manual_setup.pdf in the installation package.
    in reply to: Scada-Web not install on WinXP #132
    I can, but it would be inconvenient for other users.
    in reply to: Scada-Web not install on WinXP #130
    Please describe occured issues in details.
    What installation steps have you done?
    What errors did you get?
    in reply to: Switching counter #125
    The behavior of channels of Switching Counter type is hardcoded.
    The algorithm is:
    Fill Formula field of the channel by any correct formula and tick Formula Used checkbox.
    When the value of the formula crosses 0, the value of the channel will increase by 1.
    in reply to: Minimum data writing period #116
    Yes, you can set it to 10 or 1 second, for example. But you can’t do it using graphical interface of SCADA-Server. If you need it, do it manually by editing C:\SCADA\ScadaServer\Config\ScadaServerSvcConfig.xml in the text editor you like.
    This mode hasn’t been tested yet, it works, most likely. In this case it is a good idea to monitor size of files in C:\SCADA\ArchiveDAT and C:\SCADA\ArchiveDATCopy
    in reply to: Data charting #114
    Without registration Automatic control module works in the test mode. I think it is a good idea to add the full featured mode limited by date.
    If you send the computer code generated by the module to info _aty_ rapidscada _dot_ org, I generate a trial key.
    The same option for the chart is unavailable due to technical reasons.
    The chart component overrides the default chart and just adds the declared functionality.
    in reply to: Minimum data writing period #111
    As a workaround you can manually set the value in C:\SCADA\ScadaServer\Config\ScadaServerSvcConfig.xml
    It defines how often snapshots are stored in minute data file. SCADA-Server shell may display custom values incorrectly despite of that it works.
    If you write more details about your task I could give more efficient advice.
    in reply to: ModAutoControl.en-GB.xml not found bug #110
    I’ve sent the file to you via e-mail.
    The file is missed in the installation package. It will be added ASAP.
    in reply to: Data charting #109
    The charting component adds scaling and displaying of multiple charts.
    Could you post a link to an example of charting current data? Or explain.
