Did you check the log of the communication line? Is there something useful?
I recommend to contact the author of the MQTT driver. His email is shared on the GitHub page.
MikhailModeratorYou right, selecting a period of writing for a channel is a useful idea.
MikhailModeratorWhy do need a scheme in a dashboard?
Could you explain your case?
You can insert a link to a scheme, but it is not tested and may occur bugs.
If you do it, please describe the experience.
OK 🙂
Does it fast enough?
Try set “Chart gap” parameter to 1 second in the web app settings.
First of all, check the size of the *.sch files.
Then I recommend to press F12 in browser, open the Console tab and watch the log when a scheme is downloading. You can find what part takes more time.
Have you already created an input channel that stores max value of a day?
MikhailModeratorI think, it better to ask the author by creating an issue on GitHub.
MikhailModeratorThe author has implemented commands. See the GitHub issue for details.
Choose the way that is more easy for you according to your experience and skills.
Could you explain what calculations you need to apply? May be write an example of math formula.
Please create a new topic for this purpose.
MikhailModeratorNice 🙂
MikhailModeratorNow I’ve opened the source of the MQTT driver and realized that the author hasn’t implemented sending commands.
I created an issue https://github.com/bersim/OpenKPs/issues/6
Thank you for the description.
I’d like to ask you for 1 extra screenshot:
When you send a command there should be a appropriate line in the communication line log: https://ibb.co/mXi89w
Could you scroll the log to the moment of the command and make a screenshot of this page?
You can also find the log files at C:\SCADA\ScadaComm\LogI recommend to increase timeouts of the device to make communication slower while testing.
