Please provide screenshots of Communicator where we can see how data are polled.
Yes, the apps require administrator access. The cause is that SCADA-Server and Communicator are Windows services. So to make possible to control them, you need administrator privileges.
Try http://localhost/ If you don’t see IIS welcome page, you should install IIS as written here http://doc.rapidscada.net/content/en/installation-and-run/software-installation.htmlIf IIS is already installed, may be you should fix it.
See the description at Device Libraries – KpEmail.dll
You need a Binary command number 1 with a text that Joao noticed above.-
This reply was modified 8 years, 3 months ago by
MikhailModeratorAPI is not a file system. You should check documentation of that software what API it supports.
You can see the statuses in the Event types table.
5 is Unreliable
It means that there are no data for a period (by default 5 mins). You should check if Communicator works or not.
MikhailModeratorNow ushort is selected that is always >= 0. To make possible negative values, switch to short. Then save the template and restart Communicator.
What API of that system do you plan to use?
MikhailModeratorThank you. I think, you should tune the Modbus template in Communicator. You could also provide a screenshot of your template.
MikhailModeratorI am glad that it works now 🙂
MikhailModeratorLinq:
I think, you can select data from the archive using Linq, but I have’t tried before.One cool thing is that this archive data editing can all be tested/manipulated completely OFFLINE simply by copying one or more target archive data files locally “to play with”.
Yes, it’s true.
MikhailModeratorMost of this is table-READ based however.
You can write into a snapshot table (SrezTable). I will show how.
MikhailModerator
To do a check, also I need screenshots of the decoded values and the configuration as I noticed above. -
