MikhailModeratorYou should provide screenshots of the module settings and log of the export module.
MikhailModeratorThank you!
MikhailModeratorWow!
Could you show the screenshots before and after?
The above screenshot is too small. I can’t recognize anything.
MikhailModerator1. Go to the Modules page
2. Click the Add (+) button
3. Add ModDBExport.dll and apply the settings.
4. Select the module and click the Properties button.
You should create a new database connection in the module properties form and paste SQL requests for this connection.
What is the particular question?
This is a bit strange. On the other hand, I’m sure that the cause exists. Could you provide screenshots of the related input channels?
Configuration of Rapid SCADA is prepared on Windows, then applied on Linux. I recommend watching the videos to learn how to configure Modbus.
MikhailModeratorI’ve opened an issue on Mono https://github.com/mono/mono/issues/9458
Hope the Mono team will work on it.
MikhailModeratorHi Rodrigo,
Usually a modem is TCP client while Communicator is TCP server. You should set the TCP server type of communication channel in Communicator and allow the incoming connection on Firewall. Setup a modem to connect to the IP or DNS name and TCP port of your server. You will see that a connection is established in a communication line log. If connection is OK, Communicator polls the devices.
If something goes wrong, provide logs of the communication line.
MikhailModeratorYou may contact the Logo support, provide them communication log and ask for explanation about the device behaviour.
Could you send me an email to this address? I will estimate a cost of the update and answer by email.
Try switching the event filter to “All Events”. May be they are not visible.
Also look for the events in the GUI of SCADA-Server.
We need to understand if there no events at all or they are hidden.
Please write here about the result.
According to the communication line log, the device understands your command. Nothing happens because of a device logic. You should check that you specify the correct address and value of the commands.
Does the manufacturer provide an utility application that can send the required commands to compare data packages?
I’m sure how do you expect them to work.
Probably. You should test. -
