Viewing 15 posts - 2,521 through 2,535 (of 6,299 total)
  • in reply to: Elapsed Minute #10467
    Elapsed time starting from which moment do you need?
    in reply to: canvas support in V6 #10461
    The existing scheme engine uses HTML5 DOM model for displaying components. Using canvas only may decrease scheme features because canvas cannot show external webpage, for example.
    Creating scheme components based on canvas in DIV element is possible and can be useful for complex graphics.
    Dear Han,
    It’s depends on camera. You should set the URL of the frame component to a web page that is provided by the camera.
    in reply to: New device drivers #10455
    1. Run Visual Studio as administrator.
    2. Open the solution that contains the driver.
    3. Switch VS to Debug configuration and build the driver.
    4. Copy the created driver DLL to Communicator.
    5. Configure and start Communicator service.
    6. Attach to Communicator process from VS.
    in reply to: Automatic Migration and Deployment #10453
    We could develop such utility application by a contract.
    You can also develop it with C#. The utility should connect the Agent service and send a packed project like the Administrator app does.
    I suppose, it’s better to develop a new app for Rapid SCADA 6.
    in reply to: New device drivers #10452
    You should build your DLL in the Debug configuration in VS. Then copy to the Communicator installation directory.
    What are the detailed steps of using VisualStudio to debug the driver?
    There is no special tricks for Rapid SCADA debugging. Search for general info how to debug dlls.
    in reply to: Documentation for Older Versions #10451
    1. Go to the main docs page https://rapidscada.net/doc/
    2. Click “Version 5.6 English” in the top right corner.
    in reply to: Automatic Migration and Deployment #10447
    Thank you for your appreciation of the project.
    Assume, you have all project files in some directory. How do you need to start project deployment?
    What version of Rapid SCADA do you use?
    I suppose, there should be a command-line utility that does deployment and can be run automatically.
    in reply to: Web API, REST API, version 6 #10445
    Or there is the other way to fetch data from OPC server? I use JS and PHP.
    To get data from an OPC server, use the existing OPC client driver. See this link for details.
    If you need another thing, please specify your question.
    in reply to: How To Set Alarm Continuously #10441
    Custom logic of alarm signal is configured with the Administrator app, using formulas.
    in reply to: Chartpro Plugin #10439
    Creating a web page view does not require any programming. Just add a row in the Interface table.
    Can we define for each individual parameter different axis
    PlgChartPro.xml is a correct file name.
    An individual axis for each channel is possible only if all channels has different quantities. Because an axis is chosen for a channel according to its quantity.
    in reply to: Rapid SCADA 6 Beta #10438
    Is there a solution to this problem on V5?
    The issue is solved in the v6.
    In the meantime, I suggest adding a column for “ratio”
    Creating a function Ratio that makes linear calculation may be more clear. For example, channel formula would be
    Ratio(0.5, 10)
    in reply to: Chartpro Plugin #10434
    1. You can add a web page view to show a chart with predefined channels.
    This is an example how to add a web page view.
    Also I suggest to use Dashboard Plugin to easily display different charts.
    2. In Chart Pro configuration file (ChartPro.xml) you can define several Y-axes. Channels are bound to an Y-axis according to the channel quantity that should match the QuantityIDs parameter of the Y-axis.
    If you have questions during the implementation, please provide screenshots of the settings and results.
    • This reply was modified 3 years, 11 months ago by Mikhail.
    in reply to: Rapid SCADA 6 Beta #10430
    Channel data type should match datatype of a driver tag. The Modbus driver uses the double type for all tags.
    64bit integer data type may be useful for long counters, because its max value is bigger than double.
    When I use “ export… ” to export channels to CSV files, and I have a coding problem If I use simplified Chinese in channel names
    Please create a separate topic to discuss this issue in details and fix.
    If you need a new simplified Chinese language pack, I’d be glad to do it.
    That would help the project very much. Currently the phrases continue changing. After we release a stable 6th version, simplified Chinese translation would be appreciated.
    in reply to: How To Set Alarm Continuously #10429
    You could use a hardware relay. So you can play alarm signal independently from web browser.
    Also you need a calculated channel that indicates that alarm is active. Automatic Control Module would send commands to control a relay depending on the channel value.
