Viewing 15 posts - 2,236 through 2,250 (of 6,296 total)
  • in reply to: v6, DrvDsMqtt not publishing anything. #11485
    Could you provide steps how to modify the HelloWorld project to reproduce the issue?
    in reply to: Rapid SCADA 6 Beta #11484
    We’ve published Rapid SCADA 6 RC1 on the official website. It is stable and can be used in projects. For final release we need more docs and modules.
    in reply to: Migrating V5.84 projects to V6 #11483
    Projects for Rapid SCADA 5 and 6 have different structure. Before using an old project for new Rapid SCADA, the project has to be converted. We will provide a project converter app later.
    the RAM drive needs to be set up, is this a necessary step?
    If you use SSD, using RAM drive is important to save SSD’s life.
    How much will the performance decrease if I don’t use a RAM drive but a hard disk?
    We have not measured it. RAM drive is needed to avoid much of writing to SSD.
    If I use a RAM drive, will I lose log files after a power outage? Or is the RAM drive just caching ?
    Some RAM drive apps allow to save files on shutdown. My favorite is ROG RAM Disk.
    in reply to: Unable to receive list of plugins #11482
    The plugin list uses the external REST API, so if rapidscada.net is temporary unavailable, the list may not display.
    in reply to: Unable to receive list of plugins #11481
    To get the error details, press F12 in browser and check the Console and Network tabs.
    Plugin list displayed there is the same as http://rapidscada.net/scada/plugins/Store/StorePublic.aspx
    in reply to: Rapid SCADA 6 Beta #11471
    rapidscada_6.0.0~rc1 released.
    RC stands for Release Candidate, meaning this release is very close to a full release. Help in testing the installer and the applications is appreciated.
    in reply to: v6, DrvDsMqtt not publishing anything. #11469
    Communicator/ is a sub topic of Communicator with a zero-length sub level topic ‘. Maybe the trailing “/” should be left out.
    “Communicator/” is used in conjunction with other topic parts, for example Communicator/line001/device001/Sin
    You should tick the Detailed log checkbox in the data source properties. The file DrvDsMqtt_XXX.log contains information about sending data, for example:
    2022-11-02 11:35:16 Send Communicator/line001/device001/Sin = -0.5229836122997832
    2022-11-02 11:35:16 Send Communicator/line001/device001/Sqr = 1
    2022-11-02 11:35:16 Send Communicator/line001/device001/Tri = 5.255433325000013
    2022-11-02 11:35:16 Send Communicator/line001/device001/DO = NaN
    in reply to: v6, DrvDsMqtt not publishing anything. #11467
    So does the MQTT data source publish data or not?
    in reply to: v6, DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ? #11466
    I guess that mean it working.
    Yes.
    I will double check my previous instance setup
    For testing, you can set Module to ModArcBasic for MinCopy.
    I have some question, why not current data?
    All InfluxDB points have timestamp.
    What does read only option mean ?
    This is kind of lifehack to read data from an archive that is written by another ScadaServer. This option ensures that the data is not affected.
    Can I disable file backends if I use influx?
    Yes. In this case I suggest to use ModArcInfluxDb for Cur, Min and Hour archives. Otherwise, Webstation settings should be updated.
    in reply to: Error message xml not found #11465
    The question is duplicated.
    in reply to: Report summary of register values (table & excel) #11464
    If you have issues with displaying the above data, please provide screenshots.
    Can I export this excel data via WebStation?
    Yes, Webstation allows to export historical data to Excel.
    in reply to: V6, communicator ignores bound channel of integer data type #11455
    maybe it should be highlighted in the document regarding these data types
    You right. Currently, the documentation for v6 is not ready. Nuances of the algorithms should be added to the docs.
    in reply to: v6, DrvDsMqtt not publishing anything. #11451
    @zzz, do you get data from Communicator to ScadaServer successfully?
    in reply to: v6, DrvDsMqtt not publishing anything. #11450
    Let me try later today since I have my own Mqtt server locally and on the cloud.
    @kumajaya
    , if you already have tried the MQTT publishing data source, could you share the experience?
    in reply to: v6, DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ? #11449
    Writing of 0 data points completed successfully in 1 ms
    It looks like no channels are associated with the archive.
