Forum Home › Forums › Understanding the Software › v6, DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ?
- This topic has 10 replies, 2 voices, and was last updated 3 years, 11 months ago by
October 27, 2022 at 4:09 am #11439
zzz
ParticipantDoes DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ?
October 27, 2022 at 6:52 am #11440zzz
ParticipantI am using InfluxDB2 local install, All I get from the log is “writing 0 data point”, why ?
All channel data are of type
Double, formatOff-On.
File Archive works fine, in webstation,
I can open the channel’s minute data plot from table view.2022-10-27 14:10:00 Writing of 0 data points completed successfully in 84 ms 2022-10-27 14:10:01 Successful response from the database server 2022-10-27 14:11:00 Writing of 0 data points completed successfully in 1 ms 2022-10-27 14:11:00 Successful response from the database server 2022-10-27 14:12:00 Writing of 0 data points completed successfully in 0 ms 2022-10-27 14:12:00 Successful response from the database server 2022-10-27 14:13:00 Writing of 0 data points completed successfully in 0 ms 2022-10-27 14:13:00 Successful response from the database server 2022-10-27 14:14:00 Writing of 0 data points completed successfully in 0 ms 2022-10-27 14:14:01 Successful response from the database server 2022-10-27 14:15:00 Writing of 0 data points completed successfully in 0 ms 2022-10-27 14:15:01 Successful response from the database server 2022-10-27 14:16:00 Writing of 0 data points completed successfully in 0 ms 2022-10-27 14:16:00 Successful response from the database server 2022-10-27 14:17:00 Writing of 0 data points completed successfully in 0 ms 2022-10-27 14:17:00 Successful response from the database server 2022-10-27 14:18:00 Writing of 0 data points completed successfully in 0 ms 2022-10-27 14:18:00 Successful response from the database server 2022-10-27 14:19:00 Writing of 0 data points completed successfully in 0 ms 2022-10-27 14:19:00 Successful response from the database server 2022-10-27 14:20:00 Writing of 0 data points completed successfully in 0 ms 2022-10-27 14:20:00 Successful response from the database server 2022-10-27 14:21:00 Writing of 0 data points completed successfully in 0 msOctober 27, 2022 at 8:52 am #11441zzz
Participantsome more info
from ScadaServer.txt2022-10-27 14:09:44 [wsta][appstack][ACT] Archive Cur initialized successfully 2022-10-27 14:09:44 [wsta][appstack][ACT] Archive Min initialized successfully 2022-10-27 14:09:44 [wsta][appstack][ACT] Archive Hour initialized successfully 2022-10-27 14:09:44 [wsta][appstack][ACT] Archive Events initialized successfully 2022-10-27 14:09:44 [wsta][appstack][ACT] Archive MinCopy initialized successfully 2022-10-27 14:09:44 [wsta][appstack][ACT] Start listener on port 10000 2022-10-27 14:09:44 [wsta][appstack][INF] Archive in DAT format: /app/appstack/rapidscada6/Linux/scada/Archive 2022-10-27 14:09:44 [wsta][appstack][INF] Archive copy in DAT format: /app/appstack/rapidscada6/Linux/scada/ArchiveCopy 2022-10-27 14:09:44 [wsta][appstack][ACT] Delete outdated data from the Min archive older than 27/10/2021 2022-10-27 14:09:44 [wsta][appstack][ACT] Delete outdated data from the Hour archive older than 27/10/2021 2022-10-27 14:09:44 [wsta][appstack][ACT] Delete outdated data from the Events archive older than 27/10/2021 2022-10-27 14:09:46 [wsta][appstack][ACT] Session with ID 5923217496133782260 created 2022-10-27 14:09:46 [wsta][appstack][ACT] Client 127.0.0.1 connected 2022-10-27 14:09:46 [wsta][appstack][ACT] Session with ID -346220670448517208 created 2022-10-27 14:09:46 [wsta][appstack][ACT] Client 127.0.0.1 connected 2022-10-27 14:09:46 [wsta][appstack][ACT] User ScadaWeb is successfully authenticated 2022-10-27 14:09:46 [wsta][appstack][ACT] User ScadaWeb is successfully authenticatedfrom ScadaServer/Config/ScadaServerConfig.xml
... <Modules> <Module code="ModArcBasic" /> <Module code="ModArcPostgreSql" /> <Module code="ModArcInfluxDb" /> </Modules> <Archives> <Archive active="true" code="Cur" name="Current data" kind="Current" module="ModArcBasic"> <Option name="FlushPeriod" value="30" /> <Option name="LogEnabled" value="false" /> <Option name="ReadOnly" value="false" /> <Option name="UseCopyDir" value="false" /> </Archive> <Archive active="true" code="Min" name="30s archive" kind="Historical" module="ModArcBasic"> <Option name="IsPeriodic" value="true" /> <Option name="LogEnabled" value="false" /> <Option name="PullToPeriod" value="0" /> <Option name="ReadOnly" value="false" /> <Option name="Retention" value="365" /> <Option name="UseCopyDir" value="false" /> <Option name="WriteWithPeriod" value="true" /> <Option name="WritingPeriod" value="30" /> <Option name="WritingPeriodUnit" value="Second" /> </Archive> <Archive active="false" code="CurCopy" name="Current data copy" kind="Current" module="ModArcPostgreSql"> <Option name="Connection" value="" /> <Option name="FlushPeriod" value="30" /> <Option name="LogEnabled" value="false" /> <Option name="MaxQueueSize" value="1000" /> <Option name="ReadOnly" value="false" /> <Option name="UseStorageConn" value="true" /> </Archive> <Archive active="true" code="MinCopy" name="Minute archive copy" kind="Historical" module="ModArcInfluxDb"> <Option name="Connection" value="local-v2" /> <Option name="IsPeriodic" value="true" /> <Option name="LogEnabled" value="true" /> <Option name="PullToPeriod" value="0" /> <Option name="ReadOnly" value="false" /> <Option name="Retention" value="365" /> <Option name="WriteWithPeriod" value="true" /> <Option name="WritingPeriod" value="1" /> <Option name="WritingPeriodUnit" value="Minute" /> </Archive>from ScadaServer/Config/ModArcInfluxDb.xml
<ModArcInfluxDb> <Connections> <Connection> <Name> local-v2</Name> <Url> http://127.0.0.1:8086</Url> <Token> %token%</Token> <Username> %user%</Username> <Password> %pass%</Password> <Bucket> default</Bucket> <Org> default</Org> </Connection> </Connections> </ModArcInfluxDb>October 27, 2022 at 12:22 pm #11448
MikhailModeratorInfluxDB2 is supported.
In ScadaServer.txt there are statuses of archives. Is the MinCopy archive displayed as ready?In ScadaServer.log how many channels for archiving? For example
Number of active channels for archiving: 271October 27, 2022 at 12:23 pm #11449
MikhailModeratorWriting of 0 data points completed successfully in 1 ms
It looks like no channels are associated with the archive.October 30, 2022 at 8:13 am #11461zzz
ParticipantI am not exactly sure how that is supposed to be done.
But in the
helloworldproject on a different box, it works correctly after I added connection setting and configuredminute copyarchive to use influxdb.And I can see below message in log now. I guess that mean it working.
I will double check my previous instance setup after I regain access to the server.2022-10-30 16:05:30 Successful response from the database server 2022-10-30 16:05:45 Writing of 8 data points completed successfully in 0 ms 2022-10-30 16:05:45 Successful response from the database server 2022-10-30 16:06:00 Writing of 8 data points completed successfully in 0 ms 2022-10-30 16:06:00 Successful response from the database serverI have some question, why not
current data?
What doesread onlyoption mean ?
Can I disable file backends if I use influx?October 31, 2022 at 7:37 am #11466
MikhailModeratorI guess that mean it working.
Yes.
For testing, you can set Module to ModArcBasic for MinCopy.
I have some question, why not current data?
All InfluxDB points have timestamp.
What does read only option mean ?
This is kind of lifehack to read data from an archive that is written by another ScadaServer. This option ensures that the data is not affected.
Yes. In this case I suggest to use ModArcInfluxDb for Cur, Min and Hour archives. Otherwise, Webstation settings should be updated.
November 2, 2022 at 1:15 pm #11474zzz
ParticipantFigured out, all channels’s archive mask needs to be updated in channel db.
Issue closed.November 8, 2022 at 8:25 am #11505zzz
ParticipantWhat does read only option mean ?
You might want to have a look at the features like
Continuous QueryandRetention Policy. https://docs.influxdata.com/influxdb/v2.5/process-data/common-tasks/downsample-data/
With that, the Flux’s aggregation methods become quite versatile and flexible, this can compensate the missing average aggregation from v6.I have some question, why not current data?
I guess I just want to direct the collected data to influxdb as original as possible without oversampling, you know, e.g. pushing data that is not fresh but just because some configured interval has reached, since with influxdb’s window function can deal with unevenly paced data.
This reply was modified 3 years, 11 months ago by
zzz.
November 8, 2022 at 10:55 am #11507
MikhailModeratorI guess I just want to direct the collected data to influxdb as original as possible without oversampling
You could setup a historical archive to write data on change, defining minimum value change or period if needed.
November 8, 2022 at 10:57 am #11508
MikhailModeratorThe read only option can be used to read from a bucket where downsampled data are written. Thank you for noticing.
