Viewing 15 posts - 1,486 through 1,500 (of 6,289 total)
  • in reply to: Using Formulas With Scripts #13511
    Is there a way to edit the script to make it update every half second instead of every second?
    Open the Scripts table and check the EveryPeriod method. You can use it instead of EverySec.
    in reply to: http command #13510
    I will check.
    in reply to: Using Formulas With Scripts #13501
    If you use this formula inside the channel 101, try
    EverySec(() => { return Val() + 1; }) or
    EverySec(() => Val() + 1)
    The channel should be of the Calculated type.
    • This reply was modified 2 years, 8 months ago by Mikhail.
    in reply to: http command #13500
    Could you also provide a screenshot of the communication line log when you send a command?
    in reply to: Delay before creating an event #13496
    In Rapid SCADA 6 you can set a deadband for a limit. It’s not a time delay but also can be helpful. To make a time delay, you need to develop a formula and change channel status from the formula.
    in reply to: http command #13495
    First of all, try sending command from the device data page (in Communicator settings). Provide screenshots if it doesn’t work.
    in reply to: http command #13494
    With DrvHttpNotif you can send any parameters using GET or POST request.
    You should send a command having the code Request and text like
    grp=value1
    value=value2
    in reply to: Export to database #13483
    Use the SQL examples from this link.
    in reply to: Export to database #13482
    Yes, there is ModDbExport module in v6. The module was upgraded and improved.
    in reply to: Button to open a table #13479
    An addition to the above answer: to display a link as a button, set borders and background color if needed.
    in reply to: User management plug in #13475
    If your company (or client) uses Active Directory, it’s possible to integrate it with Rapid SCADA and manage users by Active Directory tools.
    in reply to: User management plug in #13474
    The option to assign a user management plugin is created for future use. The plugin itself has not been developed yet. We will develop it in the future.
    in reply to: cannot get opc da value #13472
    How did you solve this issue?
    in reply to: i can’t open sample example #13471
    Scheme Editor requires WCF to be installed. Check the Windows features as shown here.
    in reply to: cannot get opc da value #13467
    This page also may help.
