For now, the OPC UA server supports only current data.
MikhailModerator
The feature to export data on timer is available in Rapid SCADA 6.
Using 5.8.4, you can try the above method, but it seems too tricky.
MikhailModeratorDid you manage to connect?
The popupLocator object is declared in popup.js, which is referenced by the web pages.
MikhailModeratorIf an OPC UA server provides motor states as an array, you can read them as an array and store in a single channel having length 10. But in the scheme view, you need to address channels by their numbers. Provide screenshots of the settings for more details.
MikhailModeratorYou can use this simple utility for testing. Also try 3rd party OPC clients, such as Matrikon OPC explorer and Prosys.
I cannot find the above lines in scheme-render.jsApril 8, 2024 at 11:49 am in reply to: CurData and EventData with a difference of about 2 seconds #14356
MikhailModeratorThe above is a good example of what I was saying.
Also you can try to set an archive option to write data on each change. But it may require a lot of disk space if data change too fast.
MikhailModeratorCould you provide an example?
MikhailModeratorHow do I make the LED indicator condition show green when no alarm, and red when alarm is on
Open the Conditions property of the component and change the colors.
MikhailModeratorFor example, the device returns a list of registers A1…A10. And a manufacturer says that this is an array. A driver should create a tag that has length > 1 to support an array. But the current Modbus driver does not support this.
While OPC devices can return data of array types. And the OPC driver also supports this.
OPC UA driver in Rapid SCADA 6 can read arrays from the OPC server. On SCADA level each array element is stored in a separate channel. It’s easier to try and watch how it works.
April 4, 2024 at 11:54 am in reply to: CurData and EventData with a difference of about 2 seconds #14340
MikhailModeratorYes, event has it’s own timestamp that equals to an event creation time. While archive timestamp may be different if the archive uses a writing period. But 20 seconds difference is too big if the archive period parameter is 1 second. I would be OK if the archive writing period is 1 minute for example.
