Viewing 15 posts - 661 through 675 (of 6,288 total)
  • in reply to: OPCUA DA Gateway #16054
    Mikhail told me once that OPCUA input data goes directly to communicator devices (OPCDA servers in my example) without passing throuht RapidScada’s server Tags
    It may depend on the configuration. If you transfer data using Communicator’s data source, it comes directly. If you use Auto Control Module, data can be converted by formulas.
    in reply to: Daily Archive #16032
    There are no screenshots at the link. This conversation seems useless. I’m about to close the topic.
    Please write questions in a proper topic. This topic is about service control command.
    in reply to: Daily Archive #16022
    Elastic Report example is here.
    It can be displayed as a web page view.
    • This reply was modified 1 year, 5 months ago by Mikhail.
    in reply to: Daily Archive #16021
    The screenshot on Google Drive is not public.
    in reply to: Farm Management Module #16020
    It looks very useful. To publish the module to the Store, use this form.
    in reply to: How to forward events through MQTT driver #16019
    MQTT driver can publish channel values, but not events.
    in reply to: I have a question regarding event DESCRIPTION. #16018
    Message description is built based on channel status and value. “Defined” is a channel status. If you rename a channel status in the Channel statuses table, event descriptions will change.
    in reply to: Daily Archive #16003
    What actual result do you get in a table view?
    I mean a screenshot of the web page.
    in reply to: Send values and commands #16002
    Open Webstation – Application Options – Plugin Assignment and check that
    Plugin for sending commands is PlgMain.
    in reply to: Change output state by formula #16001
    I have problem with change state of output in the same formula, I want send impuls to my modbus device.
    The output value depends on the formula. In your formula 0 is returned. Also you should specify a device and Tag code for the channel.
    in reply to: Daily Archive #15986
    OK, the settings are clear now. What actual result do you get in a table view?
    Open the Custom Options page of the communication line settings, and add a new parameter TransMode with value TCP
    in reply to: Daily Archive #15977
    Screenshots are not available. Please fix them.
    in reply to: Daily Data #15976
