Forum Home › Forums › Uncategorized Issues › Daily Data
- This topic has 8 replies, 3 voices, and was last updated 1 year, 9 months ago by
January 8, 2025 at 4:56 am #15930
Hcinarli
ParticipantHello, I want to keep a daily record of the data I read from my Modbus device, then I want to extract the daily record I keep from the instant data and put it into 4 processes, for example, I selected the table feature as 1440 hours and daily in the table editor to keep daily data, but it does not save daily data, thanks in advance.
January 8, 2025 at 8:14 am #15935
Please clarify your question. Screenshots may help.January 8, 2025 at 9:05 am #15940Hcinarli
Participanthttps://i.imghippo.com/files/aRbF4329aVw.png
https://i.imghippo.com/files/NtXP9856NQ.png
As it can be seen in the fields I marked in the images, I can show the data I read from my modbus device hourly history data, in the same way, I created a table to show the data I read from my modbus device daily, I made 1440 minutes instead of 60 minutes from the table settings, and although dailydata is marked in the archive mask field in the relevant channel for the daily, I cannot show the daily data in the table editor. My goal is to record the data I read from my Modbus Device daily as in hourly data.
Translated with DeepL.com (free version)
January 8, 2025 at 10:41 am #15943
manjey73ParticipantBy default, the table takes data from a minute archive, perhaps choosing an archive will help in this case.
You also need to set up Graph calls for this archive.
This reply was modified 1 year, 9 months ago by
manjey73.
January 9, 2025 at 11:12 am #15962
MikhailModeratorMay be a table view is not so good to show daily data. It was designed mostly for hourly data.
Elastic Report can show daily data as HTML. You could try Elastic Report Plugin.January 11, 2025 at 3:55 pm #15971Hcinarli
ParticipantIs it not possible to do without the elastic report What I want to do is to record the data I read from my modbus device on a daily basis I tried to change the table properties, but it did not work as I wanted. In the properties of the channel I want to keep the daily data, daily data is also checked in the archive mask field, but only the hourly archive is kept in the table, thanks in advance.
January 11, 2025 at 4:31 pm #15972Hcinarli
Participantsolved thanks.
January 12, 2025 at 3:16 pm #15973Hcinarli
ParticipantHi I thought it was solved, I created a special archive type for myself for 3 minutes and configured the table editor accordingly, it kept 3 minutes of data, but the same process for daily data failed to save data every 24 hours, I shared screenshots, what is the reason or what should I do?
January 13, 2025 at 11:42 am #15976
Screenshots are not available. Please fix them. -
