Viewing 15 posts - 616 through 630 (of 6,288 total)
  • in reply to: Migrating V5.84 projects to V6 #16197
    In my project I have 62 input and 9 output channels.
    May be it would be easier to create a new project in v6. You can manually copy schemes and Modbus templates from the v5 project.
    in reply to: Show Rapid SCADA Version #16196
    According to the above link, the latest Rapid SCADA 6.4.0 (January 23, 2025) includes Webstation 6.2.0.3.
    in reply to: Migrating V5.84 projects to V6 #16191
    How many channels are in your project?
    in reply to: Migrating V5.84 projects to V6 #16190
    Try providing paths to *.rsproj files, I mean directory + filename.
    Don’t try with HelloWorld, try with your own project. Of cause, make a backup copy in advance. Anyway, many iterations will be needed.
    in reply to: Login Page #16188
    In v6, it’s possible to change a product name (stored in the language file) and replace images using the same filenames.
    in reply to: Script postgresql #16182
    This topic is about reading CSV.
    in reply to: Script postgresql #16180
    Use Database Export Module to export data to the DB.
    Use DrvCsvReader for reading CSV files.
    • This reply was modified 1 year, 3 months ago by Mikhail.
    in reply to: Using AD for login #16171
    > Is there a manual how to “create a PostgreSQL database
    I suppose, PostgresSQL provides a manual to do that. PostgreSQL is not a part of Rapid SCADA.
    ScadaInstanceConfig.xml already contains settings to connect to the local PostgreSQL database, named rapid_scada, using postgres/postgres for username and password. Use the existing settings for testing.
    in reply to: Can logs be recorded in the autocontrol module #16170
    The module writes a log into the ModAutoControl.log file. It can be found in ScadaSever\Log
    in reply to: ChartPro export function #16169
    Also change MaxReportPeriod in ScadaWebConfig.xml
    in reply to: Hide floating menu #16168
    You can hide menu by editing ScadaWebConfig.xml, the DisplayOptions section.
    in reply to: Custo Web Page not uploading #16162
    in reply to: x.509 Certificate Authentication #16161
    Please clarify your question.
    in reply to: Custo Web Page not uploading #16158
    Custom pages are not part of a Rapid SCADA project. They should be copied as files manually. Use WinSCP for this purpose, for example.
    in reply to: Events not changing #16157
    Event archive should be selected. An empty value means all default archives.
