Viewing 15 posts - 6,241 through 6,255 (of 6,268 total)
  • in reply to: Data charting #114
    Without registration Automatic control module works in the test mode. I think it is a good idea to add the full featured mode limited by date.
    If you send the computer code generated by the module to info _aty_ rapidscada _dot_ org, I generate a trial key.
    The same option for the chart is unavailable due to technical reasons.
    The chart component overrides the default chart and just adds the declared functionality.
    in reply to: Minimum data writing period #111
    As a workaround you can manually set the value in C:\SCADA\ScadaServer\Config\ScadaServerSvcConfig.xml
    It defines how often snapshots are stored in minute data file. SCADA-Server shell may display custom values incorrectly despite of that it works.
    If you write more details about your task I could give more efficient advice.
    in reply to: ModAutoControl.en-GB.xml not found bug #110
    I’ve sent the file to you via e-mail.
    The file is missed in the installation package. It will be added ASAP.
    in reply to: Data charting #109
    The charting component adds scaling and displaying of multiple charts.
    Could you post a link to an example of charting current data? Or explain.
    in reply to: KpOpc.en-GB.xml not found bug #105
    The issue has been fixed.
    Download the latest version of Rapid SCADA, extract ScadaCommCtrl.exe from ScadaComm.zip and overwrite the existing file in C:\SCADA\ScadaComm directory.
    in reply to: KpOpc.en-GB.xml not found bug #102
    Thank you for the feedback. This bug will be fixed within a few days.
    in reply to: Device template #100
    KpSms.dll has no additional properties.
    KpOpc.dll properies are specified for a device not for the whole library.
    You don’t need to edit KpOPC_XXX.xml manually. Open the device properties from a popup menu by right clicking the device item of the tree. Device configuration form opens as shown in the article. If you open the configuration form you will easily understand the meaning of the XML.
    in reply to: Output command value #99
    Yes, it’s possible. You need to:
    1. Add the list of command values into Command values table using SCADA-Administrator.
    2. Add an output channel of Standard type. Select your list in Command values field of the output channel.
    3. Create a formula and specify it for the output channel.
    4. When you send a command the formula converts the given index of list value to the new value. Pay the attention that the list is indexed starting from 0.
    in reply to: SCADA-Administrator input Channles #97
    Of course not. It depends on your hardware, power supply, etc.
    In some industries there are very strict requirements for system safety.
    Rapid SCADA works stable 24×7.
    in reply to: SCADA-Administrator input Channles #94
    In my opinion you need to apply hardware protection of your system in case that server breakdown.
    in reply to: Automatic output commands #93
    I have replied here
    in reply to: SCADA-Administrator input Channles #91
    Yes, you have correctly understood the mechanism of interaction between Rapid SCADA applications.
    in reply to: SCADA-Administrator input Channles #89
    Using formulas you can perform calculations but can’t send a command. There is another tool for sending commands depending on conditions: Automatic Control Module.
    Automatic Control Module is commercial, the cost is US $20. You can try it for free in the test mode.
    If the price is too high, it is possible to develop your own implementation as described here.
    • This reply was modified 11 years, 4 months ago by Mikhail.
    in reply to: SCADA-Administrator Output channels #87
    Thanks for Number in Russian issue. It will be fixed.
    in reply to: SCADA-Communicator Device Libraries #86
    Modbus, OPC and AT commands are commonly used worldwide.
    VKT-4M, etc. are specific for Russian customers, therefore they were excluded from the installation package to keep the product clear.
