in the Modbus example, t4_max is an signal received from the device, but, supposing I want to setup t4_max as an automatic response to the device in order to cool it (for example) sending a command throught Resett4_max, could I write a formula in Formula field of input channel 104 (t4_max), something like this:
If t4>t4_upperLimit then send 1 to t4_maxOutputChannel
My idea is when t4 channel is higher tan the specified upper limit for it, then the input channel t4_max sends 1 (ON) to its output channel associated (11 in this case) in order to, the output channel Resett4_max send 1 (ON), throught command number 5, to the fan of the device.
Is possible to write a formula which does it?
