MikhailModeratorIs there a free HMI/Scada free IMG repository available?
Not yet. I usually look for images in Google Images
How does Dinamic IMG works and what is the format for it?
It shows an image depending on Input channel value and its Conditions property.
You can use PNG and JPG image formats.How can i make new IMGs? Is it possible to use Inkscape-Sage?
Any image editor. I use Microsoft Visio. Inkscape is good, but you should convert images to PNG or JPG.
For example, is it possible to make a gauge that the pointer changes according to the input of a tag?
For now you should create a set of images with different levels and use Dynamic picture component. In the future such components will be developed.
MikhailModeratorAfter getting every block of data from Communicator, the calculated channels are updated. Could you describe the issue in details?
First of all, make sure that the web site on 192.168.0.12 is accessible: try to open http://192.168.0.12
If not, may be the cause is firewall.
MikhailModeratorThank you very much for the detailed research.
The fix is ready. Please send a letter to info -a- rapidscada.org, I will send you the fix to try.
MikhailModeratorBTW… schemes are working too! good job!
magic 🙂
MikhailModeratorI can’t reproduce the error. Could you set active only one device and only one element group in the template? Then post a part of log and the displaying values as you did.
After polling you should stop Communicator and then look for displayed values to avoid their change.
MikhailModeratorI will check today.
MikhailModeratorI have to send you the update of Chart Pro. Do not use the old Dll
MikhailModeratorI’m glad that it works 🙂
I think the issue with web.config depends on IIS version.
The update overwrites ScadaDiag.dll.Just copy the DLL from Chart Pro component.
MikhailModeratorI’ve sent. Please let me know about the result.
MikhailModeratorI’ve found IEEE754 calculator: http://www.h-schmidt.net/FloatConverter/IEEE754.html
It may help.
MikhailModeratorYou right that the reason of the issue is incorrect decoding. I don’t think that it is a bug. Most likely the responses are differ.
Please, post a part of communication log where the response is decoded incorrectly.
MikhailModeratorInteresting error. Works like Mono .NET on Linux.
If it’s possible, use newer OS, please. If not, I can send you an update that should fix this issue with charts, but the update does not fix issue with schemes.
MikhailModeratorIn the Table editor just focus on the left table and hold Enter button. Channels will be added one by one.
The editor will be moved to the web application that is why there is no reason to update the GUI version.
MikhailModeratorUse clone channels or create channels functions in SCADA-Administrator.
