Viewing 15 posts - 5,821 through 5,835 (of 6,288 total)
  • in reply to: Several days/channels graphs are generated slooooowly #1232
    Nothing is impossible 🙂
    in reply to: Firefox left w/ graphs open overtakes RAM #1231
    No, I think it’s better to release the new web app ASAP.
    in reply to: Excel Exporting #1224
    Do you mean that you need to store data every second?
    in reply to: Microsoft SilverLight #1222
    Within a few months.
    in reply to: Microsoft SilverLight #1219
    The spring was too optimistic. The work is in progress. You can see a screenshot here. I hope the result will satisfy our users.
    in reply to: how they work: Events, Alarms and Limits #1217
    WRITE EVENTS: if false, no event for the channel will be written and shown.
    EVENT SOUND: plays beep in browser. Just try.
    EVENT ON CHANGE: on any change. Usually the option is used for discrete values.
    EVENT ON UNDEFINED: e.g. connection is lost. Event fires when the channel status is 0.
    LIMIT: I recommend trying it using SCADA-Server generator.
    Object field is optional. Device field is required if channel value is measured by a device.
    Are any events shown when in Report/List Chart view?
    Sorry, I didn’t catch the meaning.
    Have a nice weekend too 🙂
    in reply to: Modbus Data Recorder Registers #1216
    What is load profile?
    in reply to: Managing events #1212
    Based on your ideas I can generate inherited ideas 🙂
    in reply to: Managing events #1211
    Thanks for the ideas!
    To view all daily events, you should export them to Excel.
    Checked events have the same behavior as others.
    users should not have access to that tool.
    Users must not have access to the server file system.
    in reply to: Managing events #1209
    How/where could I see/configure more than the last 9-10 events?
    Use SCADA-Web Configurator -> Visible events count
    How can I easily do an event sent an email ? Do I need to create a rule on Autocontrol for each channel
    Yes, you should create a rule. If it’s enough to receive the same message, you can create some kind of aggregation channel. In case of using limits, you can specify trigger on status.
    Where are they stored (in case you need to delete ie… 100’s) ?
    See directory settings of SCADA-Server.
    in reply to: Service – create channels: data was truncated ?? #1206
    Fixed. Thank you for the bug report.
    in reply to: RapidScada on Linux #1205
    Yes. Download Rapid SCADA Mono. Manual is made for Debian.
    But in the current version schemes are not accessible. The new web app is OK.
    in reply to: New Web App Idea? #1203
    Hmm in the place of the event window? Or alongside the event window?
    Custom Data window. Events closes when another window is shown.
    In any case a minimize button for the new window if there is one and a minimize button for the event window would be nice.
    It exists – the gray circle with arrow.
    the event window will automatic open again when a new event happens
    Notifications like Skype would be nice, but not in beta version.
    in reply to: Using a Virtual Server #1198
    in reply to: Using a Virtual Server #1197
    can i run RapidScada in a virtual server in Azure or Amazon?
    Yes. Talking about Azure, you have to use virtual server for SCADA-Server and SCADA-Communicator and you can use Web App for SCADA-Web.
    Does the licenses for ACM (Automatic Control Module) and Chart Pro/List work on those?
    Yes.
    If you try Amazon, please tell about the experience.
