Forum Home › Forums › Development and Integration › Service – create channels: data was truncated ??
- This topic has 3 replies, 2 voices, and was last updated 10 years, 6 months ago by
May 16, 2016 at 1:47 pm #1184
inpelsaParticipant16/05/2016 13:10:40 Create channels ----------------------------------- Check dictionaries. Create channels. Count of added output channels: 0. Count of added input channels: 159.. Count of errors: 8. Channel 1356: The data was truncated while converting from one data type to another. [ Name of function(if known) = ] Channel 1375: The data was truncated while converting from one data type to another. [ Name of function(if known) = ] Channel 1377: The data was truncated while converting from one data type to another. [ Name of function(if known) = ] Channel 1378: The data was truncated while converting from one data type to another. [ Name of function(if known) = ] Channel 1383: The data was truncated while converting from one data type to another. [ Name of function(if known) = ] Channel 1384: The data was truncated while converting from one data type to another. [ Name of function(if known) = ] Channel 1385: The data was truncated while converting from one data type to another. [ Name of function(if known) = ] Channel 1386: The data was truncated while converting from one data type to another. [ Name of function(if known) = ] Channels have been created with errors.Those channels are NOT created.
Could it be because joining device and channel name is >50 characters ?
– Would be useful to create them any way
– Better error description: “Channel name was truncated. Exceeds 50 chars!”
– Why 50 chars ? (I mean, knowing it it’s ok but… why not 100?)May 16, 2016 at 3:39 pm #1185
MikhailModeratorI will check.
Is there any additional info in C:\SCADA\ScadaAdmin\ScadaAdmin.err ?May 16, 2016 at 3:59 pm #1186
inpelsaParticipant2016-04-28 18:17:56 <SRVSCADA><Administrador><EXC> Error saving the table changes to the database: The column "Channel type" cannot contain null values. 2016-04-28 19:34:27 <SRVSCADA><Administrador><EXC> Error saving the table changes to the database: The column "Channel type" cannot contain null values. 2016-05-16 13:10:40 <SRVSCADA><Administrador><EXC> Channels have been created with errors. Update the open tables to display the changes. 2016-05-16 16:08:43 <SRVSCADA><Administrador><EXC> Error saving the table changes to the database: The column "Name" cannot contain null values. 2016-05-16 16:08:54 <SRVSCADA><Administrador><EXC> Error saving the table changes to the database: The column "Name" cannot contain null values. 2016-05-16 16:09:04 <SRVSCADA><Administrador><EXC> Error saving the table changes to the database: The column "Name" cannot contain null values. A duplicate value cannot be inserted into the column "Number". 2016-05-16 16:09:12 <SRVSCADA><Administrador><EXC> Error saving the table changes to the database: A duplicate value cannot be inserted into the column "Number". 2016-05-16 16:09:42 <SRVSCADA><Administrador><EXC> Error saving the table changes to the database: A duplicate value cannot be inserted into the column "Number". 2016-05-16 16:09:48 <SRVSCADA><Administrador><EXC> Error saving the table changes to the database: A duplicate value cannot be inserted into the column "Number". 2016-05-16 16:09:52 <SRVSCADA><Administrador><EXC> Error saving the table changes to the database: A duplicate value cannot be inserted into the column "Number". 2016-05-16 16:15:22 <SRVSCADA><Administrador><EXC> Error saving the table changes to the database: The column "Name" cannot contain null values.No more details.
I had that same error 2 times, same amount I used the same device template.
I shortened device field names and got no errors, it should be that.
May 18, 2016 at 7:26 am #1206
MikhailModeratorFixed. Thank you for the bug report.
