Viewing 15 posts - 5,791 through 5,805 (of 6,288 total)
  • in reply to: WCF service error #1303
    Read this thread.
    The new version of the web app is under construction: http://forum.rapidscada.org/?topic=new-web-app-idea/#post-1281
    in reply to: Newbie #1301
    This article helps you to connect to OPC server.
    I recommend to test KpGS828.dll from the driver pack too. If it works, it’s preferable than OPC because of reliability.
    English version of the driver pack will be released when it includes more than 1 driver useful for the wide range of countries. Thanks to Washu Hakubi about the notice about ASCII encoding of readme.txt
    in reply to: Newbie #1295
    May be you should ask a manufacturer whether GSX4-MS is able to communicate with a PC using Modbus protocol as a Modbus gate (example). In this case you can use Modbus register map which should be included in a manual of the sensors.
    in reply to: Newbie #1294
    This is not Modbus, unfortunately. It looks very similar to the protocol used by GS828 logger. Try using the driver pack. Then translate readme.txt and install it.
    You don’t need to configure a template, just configure polling.
    Do you need inputs and outputs of GSX4-MS? If not, it overfunctional and complex for your task for my opinion. Ethernet-RS-485 converter like this one is enough.
    in reply to: New Web App Idea? #1291
    Try using Chrome of Firefox.
    The standard Android browser may be outdated. I will add browser validation and displaying message whether a browser is not supported.
    in reply to: Newbie #1289
    Does GSX4-MS use Modbus protocol to communicate with PC and work as a gate between your devices and server? First of all, you need to realize what kind of protocol (over TCP) is used for interacting with GSX4-MS.
    If it uses Modbus, you should configure Rapid SCADA as described in the article http://rapidscada.org/connecting-devices-using-modbus-protocol/
    in reply to: New Web App Idea? #1288
    Write here if you think that the web app behaves weird or unexpected ))
    1. I think the logo and the title Rapid SCADA are enough. May be copyright will be in the about page. I’m not sure, should I write “copyright” for the open source software or not.
    2. As shown in the screenshot above.
    3. Information about the user. May be there will be user rights info. It is not implemented for now.
    4. It uses .NET 4+.
    .NET 5 is not widely supported by hosting providers.
    I think it will work on Apache + mod_mono, but test this configuration please.
    in reply to: New Web App Idea? #1283
    Try it on your PC, phones, etc., please. If there are some bugs, let me know. It is a good time to fix them.
    P.S. IE is not supported. Chrome, Firefox and Edge are OK 🙂
    in reply to: New Web App Idea? #1281
    The prototype is here http://demo.rapidscada.net/
    Login and password as usual: admin / 12345
    in reply to: how they work: Events, Alarms and Limits #1279
    Something wrong with the image.
    It requires changes in SCADA-Server logic. The changes may be done within a common queue of tasks or may be done fast for a fee.
    As a workaround, limits can be implemented using formulas, but in this case you need separate channels for alarm signalling.
    in reply to: how they work: Events, Alarms and Limits #1274
    Do limits are set for those channels?
    in reply to: how they work: Events, Alarms and Limits #1270
    Uncheck Event on undefined checkbox for these channels.
    in reply to: Copyright on footer #1267
    Please, remind me by email to send you the prototype.
    in reply to: Copyright on footer #1265
    OK, the color and font of the link are not important for me. The link should be visible to users and be clickable. Could you show me a design when its beta version will be ready?
    I have to warn that the new web app is fully redesigned and when it will be released, you will need to make design with your brand again. May be it’s better to use the new design as a base. I can send you the prototype.
    in reply to: Copyright on footer #1263
    Could you add a link to rapidscada.org with a text like “Powered by Rapid SCADA” near “designed by”?
