Viewing 15 posts - 556 through 570 (of 6,288 total)
  • in reply to: Event marker not found #16360
    First of all, we need sample data to reproduce the issue.
    Please do the following:
    1. Save the damaged file.
    2. Make sure that new events cannot be added to that certain damaged file.
    3. Share the damaged file using a cloud drive, so we can reproduce the issue.
    in reply to: Register reading with Modbus TCP #16359
    Try the Modbus parser https://rapidscada.net/modbus/ to find mistakes in requests.
    in reply to: XML Content Translator for SCADA 6 #16357
    I noticed that the culture name of the translation was changed from zh-Hans to zh-Hans-CN. The second is a region-specified culture.
    Could you please clarify what the difference is from a user experience perspective?
    What caused the change?
    • This reply was modified 1 year, 1 month ago by Mikhail.
    in reply to: Configuring DrvMqttPublisher #16353
    There are 2 ways to publish data via MQTT:
    1. Using the DrvMqttPublisher driver. Use this way to publish data of the selected channels.
    You should select the MQTT type of communication channel. Add a device, and set up the device’s properties.
    2. Using the DrvDsMqtt driver to create an MQTT data source. It’s more handy when you need to publish all data of the specified devices.
    Try to configure it intuitively, and publish screenshots if some settings are not clear.
    in reply to: Register reading with Modbus TCP #16352
    This video may help.
    If you add links to the screenshots of your settings and data, it would be useful to resolve the questions.
    in reply to: Scada webstation not getting open #16344
    in reply to: XML Content Translator for SCADA 6 #16342
    I have downloaded the translation and I will try to merge it. It may take some time.
    Also I found that the text of Project properties popup windows does not exist in the xml files
    Indeed, this needs to be fixed.
    in reply to: Download or upload configuration #16341
    Likely it is Rapid SCADA 5.6.0 released on December 26, 2018.
    I recommend to create a project from scratch, because for small projects it is more efficient. You can copy the existing schemes and Modbus templates from the old to the new project.
    in reply to: Scada webstation not getting open #16340
    The web browser in the 2nd picture looks very old. You should update the browser to the latest version.
    in reply to: Download or upload configuration #16336
    This topic is about migration.
    5.1.1.0 – what application version is this?
    How many channels in the configuration database?
    in reply to: Event marker not found #16334
    You right. Even if an event file is corrupted, it should be possible to append new events to it, and those events should be displayed in the web interface. Could you check how new events are added to a damaged file?
    in reply to: about chart plugin #16333
    Please email me to get the details.
    in reply to: about chart plugin #16329
    Chart and Chart Pro plugins allow to select archives for retrieving data. But it’s not possible to display data from 2 archives on the same chart area.
    To display charts from different archives, Dashboard plugin can be used. It would be 2 different charts on the same dashboard.
    • This reply was modified 1 year, 2 months ago by Mikhail.
    in reply to: Event marker not found #16328
    I think, you should use power back-ups that can safely switch off your server.
    Is Rapid SCADA installed on a computer or Linux-based controller?
    in reply to: Monthly achieve #16323
    Month can have a variable number of days, so a period length can be different. It has not been implemented yet. May be this feature will appear in the future. Currently, I suggest to write data every day, and use only the needed timestamps.
