Viewing 15 posts - 5,401 through 5,415 (of 6,289 total)
  • in reply to: Communication errors #2215
    Hi Marek,
    Probably the device uses a derivative protocol based on Modbus, but not standard Modbus. And this is the cause of the problems. Please read carefully the device manual. What is written in the manual about the supported protocol?
    in reply to: Windows XP Compatibility #2214
    Do you mean that you can open the web application locally, but can’t access remotely?
    HTTPS may require additional setup. Does HTTP work?
    in reply to: Communication errors #2207
    Try requesting 8 coils.
    in reply to: Commands in Modbus #2206
    It’s difficult to understand what values are expected in Communicator?
    in reply to: Communication errors #2205
    in reply to: Communication errors #2204
    According to the Modbus specification, in the response
    00 00 00 00 00 06 02 01 02 88 02
    06 is “Number of following bytes”. You can see only 5 bytes after 06. So the response is not correct.
    The correct response would be 00 00 00 00 00 05 02 01 02 88 02
    I think, Simply Modbus doesn’t validate the incoming data.
    Do you have any idea why the device sends incorrect Modbus packages?
    in reply to: Links in the Scheme #2203
    Please clarify your question.
    in reply to: Dashboard launch prompt Insufficient Right for chart #2202
    I suppose, you should install and switch on the Chart Pro plugin. It is used by Dashboard if a chart contains more that 1 input channel.
    in reply to: Alien LiveChart or Gage #2195
    The example of using the API.
    in reply to: Alien LiveChart or Gage #2194
    Find the API here. The descriptions of the methods are included in this file as comments.
    in reply to: Windows XP Compatibility #2193
    1. No. Don’t use the previous versions of Rapid SCADA. Install the actual.
    2. Yes, you can.
    Note: Rapid SCADA doesn’t officially support Windows XP and it is not tested on XP, but it should work most likely. The web app have to be installed manually.
    in reply to: Communication errors #2192
    Unfortunately, the link to the image you provided doesn’t work. Can you post the correct link?
    in reply to: Communication errors #2179
    The device sends not enough bytes: Receive (4/5). 5 bytes expected in the second part of package according to Modbus standard.
    You can analyze packages using http://modbus.rapidscada.net/
    If ModbusPoll can show communication protocol, let’s compare with Communicator.
    in reply to: Button object #2177
    Set the properties:
    Action = Send command
    Output channel = output channel number that you already created in Administrator to turn on/off a relay.
    in reply to: Get wrong values from registers #2176
    Please provide the additional info:
    1. Screenshot of Modbus template
    2. Screenshot of the values that you receive (Device Data tab in Communicator).
    3. What values you expect?
    Probably, you should try different order of bytes (in Modbus template) to decode floats. For example, 2301
