Windows XP Compatibility
Forum Home › Forums › Understanding the Software › Windows XP Compatibility
  • #2188
    marcunni24
    Dear all,
    I want to install Rapid Scada on a PC running Windows XP. I have two questions on this topic:
    1) Does the previous versions of Rapid Scada support the current dashboard and chart-pro plugins?
    2) Let´s suppose I have two PC’s now. One running Windows XP (“A”), and another one running Windows 7 (“B”).
    Let´s assume also they’re on the same network.
    If I install the software on the PC “B” (acting as Server), can I use the PC “A” as a Client?
    What I mean is, if PC “A” doesn’t have ANY installed Rapid Scada software, is it enough with just opening a web-browser on PC “A”, and entering “https:’IP Number of PC B‘/Scada” ?
    Is it possible to view all the screens (dashboard, chart-pro) and interact with the Scada in the same way I could do in the PC “B” (with all the software installed)?
    I don’t know If I’ve been clear with my question.
    Thanks a lot in advance for taking the time to read this.
    Kind regards,
    Martin
    #2193
    1. No. Don’t use the previous versions of Rapid SCADA. Install the actual.
    2. Yes, you can.
    Note: Rapid SCADA doesn’t officially support Windows XP and it is not tested on XP, but it should work most likely. The web app have to be installed manually.
    #2213
    marcunni24
    Dear Mikhail,
    Thanks for your response.
    I´ve tried accessing “https://192.168.X.X(my IP number)/Scada” from 3 different PCs.
    I’ve deactivated Windows Firewall, and also propietary-antivirus-software firewalls.
    I’ve disabled anti-pop up extensions on every browser.
    I’ve tried making a ping to all PC’s, they all see each other correctly.
    I’ve set all the Network connections as Private.
    I keep getting the error message “(Web browser) can´t establish a connection with the server at 192.168.X.X”
    What else could be missing?
    Note: NONE of the 3 PC’s has any SCADA software installed (neither web-browser, nor any other of the modules). Two of them are running Windows 8, and the other one Windows 10.
    Thanks again for the support.
    Regards,
    Martín
    #2214
    Do you mean that you can open the web application locally, but can’t access remotely?
    HTTPS may require additional setup. Does HTTP work?
